Maida regulator
Maida regulator
Old 31st December 2010, 02:26 AM   #21
tomchr is offline tomchr  Canada
tomchr's Avatar
That's why o'scope probes come with probe hats. Clip on the probes, remove your shaking sweaty fingers, read scope.
The Pomona clippy leads work well also. Just keep in mind that many clip leads are only rated at 60 V or so. Some of mine are fraying where the wire connects to the clip. If one isn't careful, one can get chocked by those fraying ends...
~Tom
Old 31st December 2010, 03:29 AM   #22
BRSHiFi is offline BRSHiFi  United States
Previously known as kingden
Default Scope Measurement
I measured my regulator output on DC coupling and found no ripple. I had a voltage divider cause my scope can only handle 400 volts. That may have made the ripple less visible if not invisible. Once I get access to a better scope at school I will do an AC coupled measurement and see what happens. I will also replace the IRF820 with a FET with a lower Drain to Source impedance that can handle more current. I used the IRF820 because I had a few on hand.
Maida regulatorHide this!Advertise here!
Problem with Maida regulator commstech Tubes / Valves 17 20th April 2009 02:14 PM
Using a Maida Regulator with a CCS BL21DE3 Tubes / Valves 4 17th July 2008 04:42 PM
Maida regulator billr Tubes / Valves 15 23rd September 2007 03:19 PM
Maida's regulator mark_titano Tubes / Valves 3 29th January 2006 02:26 PM
