New Guy w/my Foreplay
Old 9th February 2003, 02:44 AM   #31
Sch3mat1c is offline Sch3mat1c  United States
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Yes, clear-top 12AU7s..(exactly as pictured) I picked 'em over top getter because they look much more 1337
(And it's not PAIR, it's a HEPTET! For output of course...a whopping 6W into 6.6k )
Tim, Senior Thread Hijacker
Old 9th February 2003, 02:49 AM   #32
Wardsweb is offline Wardsweb  United States
What's the scoop on your avatar
Sch3mat1c
Old 9th February 2003, 03:11 AM   #33
Sch3mat1c's Avatar
WOT Headphones amp. (Choky knows WOT as With Output Transformer. )
6DJ8 in parallel, parafeeding (RC coupling) a 50:50k ohm input transformer in reverse (mmm, mu-metal core).
Current power source is a crappy deal I made years ago, does 6.3VAC + 100VDC 15mA.
Old 9th February 2003, 03:12 AM   #34
Sch3mat1c's Avatar
Humm I attached a photo to that...oh well.
Full size of the avatar:
Old 9th February 2003, 03:13 AM   #35
Cool!
Old 9th February 2003, 03:14 AM   #36
Sch3mat1c's Avatar
Thanks!
Underside:
Old 9th February 2003, 03:16 AM   #37
Sch3mat1c's Avatar
Probably wouldn't hurt to have some blocking resistors or something in here somewhere, but whatever.
Ah heck, it's too tight
- Not shown: a few Rs and Cs in series with the input to alter the F response. Bass is too boomy with my $30 RadioSnack headphones.
Tim
Old 9th February 2003, 07:19 PM   #38
7N7 is offline 7N7  United Kingdom
7N7's Avatar
Originally posted by dhaen
Hmm,
But, just because a valve was not designed for an audio application in the first place, does not necessarily mean it'll be no good for audio.
This of course is absolutely correct. My recent work tells me that the 6DN7 (line osc/output dual triode) should make (and apparently does make) a very good valve for audio.
Unfortunately ECC82/12AU7/5963/6198 etc, does not.
7N7
Plug them in and light them up
Old 9th February 2003, 07:29 PM   #39
7N7's Avatar
Originally posted by Wardsweb
For what it's worth, a reply from another board:
The CV 4003 and the ECC82 are not the same. The ECC was manufactured specifically for audio application. This doesn't mean the CV 4003 is crap, just not manufactured to the same exacting standards that the ECC series.
This is not true.
CV4003 was made to very exacting standards; also known as Mullard's M8136, it was manufactured to meet a military specification. CV4xxx series valves are ruggedised and had to meet a number of stringent tests in this regard (cf the American "W" suffix). All the Mullard "M" series valves were special quality, which is why they received thier special nomenclature. Brimar's "T" ("trustworthy") range was another example of the same thing.
Your average ECC82/CV491 was turned out by the million, and was probably very good - within its metier, which was TV sets, instrumentation, guitar amplifiers etc.
Not in my amplifiers though (and neither is CV4003/M8136).
7N7
New Guy w/my ForeplayHide this!Advertise here!
Foreplay III pre amp jtwrace Tubes / Valves 2 18th May 2009 02:57 AM
FS - Bottlehead Foreplay III john65b Swap Meet 2 16th July 2007 03:14 AM
Bottlehead Foreplay FS idex Swap Meet 3 8th January 2006 11:23 PM
Bottlehead Foreplay. castlesteve Swap Meet 2 14th June 2004 08:05 PM
first time foreplay perhellion Tubes / Valves 2 19th March 2002 01:44 AM
Copyright ©1999-2017 diyAudio
