New Guy w/my Foreplay
Old 7th February 2003, 09:09 PM   #11
harvardian is offline harvardian
From upscaleaudio
Here is his description:
12AU7/ECC82 CV4003 Mullard. HEAVEN!!!! Attn: Rogue and Conrad Johnson owners and those with other "picky" preamps!! I had about enough of the PV-10, 11, and 12 being a bit tough on 12AU7s, and was suggesting folks stay with Chinese or RFT even though they don't sound as good as a Mullard. We now have a test where we can supply you with premium tubes that are quiet and don't go microphonic.
The Mullard CV4003 is a wonderful tube British tube with the midrange we crave. For premium select $35. For Private Reserve $40. For Rogue/CJ owners, we have a special test that only 5 out of 100 will pass. $45 each, but you won't have any more problems, so it's worth it.
I have the $40 ea type.
doing my part to Keep Austin Wierd.
Old 7th February 2003, 11:55 PM   #12
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Looks pretty, and nice
Do I see a small PCB towards the back?
Old 8th February 2003, 12:15 AM   #13
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
Originally posted by harvardian
From upscaleaudio
What is this nonsense? The Mullard ECC82 is a field scan valve (an application that does not require low distortion. The one remarkable feature about this valve is its consistency between manufacturers and samples. Selection is not necessary. They are all equally poor for audio.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 8th February 2003, 12:21 AM   #14
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Default ECC82.
He,he...and if you really want to listen to the worst of this kind try the nickel plated 6189 as was used by the French postal services and usually made by Cifte...yuk.
Instead of spending money on so called premium 12AU7A/ECC82s it would be much better to mod the preamp and use a similar gain valve such as the 6CG7/6FQ7 or better still a 12BH7A.
Frank
Old 8th February 2003, 12:25 AM   #15
dhaen's Avatar
Hmm,
It may well be the case about the ECC82.
But, just because a valve was not designed for an audio application in the first place, does not necessarily mean it'll be no good for audio.
Old 8th February 2003, 12:36 AM   #16
fdegrove's Avatar
Default ECC82.
Not all that many tubes were designed with audio use in mind anyway.
And amongst those that weren't designed with this particular use in mind, there are a lot of various types out there that all sound a lot better than an ECC82.
Frank
Old 8th February 2003, 12:39 AM   #17
EC8010's Avatar
I take your (logical) point. Sadly, very few valves not designed for audio are any good for audio. The ECC82 is very definitely an astringent citrus fruit.
Old 8th February 2003, 12:51 AM   #18
dhaen's Avatar
EC8010,
That too might be true. The funny thing to me is the number of valves that I knew in my previous RF life (teens) that have become "standards".
ECC88
EC88
ECC189
EF80
EF184
PCF80
Just a few examples...
Old 8th February 2003, 01:39 AM   #19
EC8010's Avatar
ECC88
EC88
ECC189
EF80
EF184
PCF80
I take your point. There are a few other applications that also require low distortion. RF front ends, FDM telephone amplifiers, and good IF strips. I'm not quite sure what the variable-mu ECC189 is doing in your list, but the EF184 is one of my favourites. It's a good triode, and it makes a good constant current sink.
Old 8th February 2003, 03:37 AM   #20
Sch3mat1c is offline Sch3mat1c  United States
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
FU! I love 12AU7
New Guy w/my ForeplayHide this!Advertise here!
Foreplay III pre amp jtwrace Tubes / Valves 2 18th May 2009 02:57 AM
FS - Bottlehead Foreplay III john65b Swap Meet 2 16th July 2007 03:14 AM
Bottlehead Foreplay FS idex Swap Meet 3 8th January 2006 11:23 PM
Bottlehead Foreplay. castlesteve Swap Meet 2 14th June 2004 08:05 PM
first time foreplay perhellion Tubes / Valves 2 19th March 2002 01:44 AM
Copyright ©1999-2017 diyAudio
