diyAudio Sponsor
Old 15th September 2007, 11:40 PM   #1
Default will a 12ax7 sub for 12dw7/7247 ?
I recently bought a bogen pa amp and it uses both 12ax7's and 7247's in the preamp. My question is can I use a 12ax7 in place of the 7247 or do I need to change some resistors. I am asking simply to learn more about the tubes as I am learning how to repair tube amps and radios. Any help is greatly appreciated. Thanks folks
Old 16th September 2007, 12:21 AM   #2
Ty_Bower's Avatar
No. The 12DW7 is one half 12AX7 plus one half 12AU7. If you put a 12AX7 in its place, one half will be perfect and the other will be all wrong.
Maybe if you could track down a schematic for your Bogen, and determine how the 12DW7 is being used (pre-amp, phase inverter, tone circuit, etc.) it might be possible to figure out a solution.
Old 16th September 2007, 02:40 AM   #3
Default no
12ax7 is hi mu both halves 7247 is 1/2 hi mu 1/2 lo mu
beside a difference of gain from 10 to 50, lo mu's have much higher bias... which means plate resistor around 10k not 100k
Old 16th September 2007, 07:48 AM   #4
Thanks for the info. When I first got the amp, there were 12ax7's in two of the 7247 sockets and I though I replaced them with the proper tubes, I wondered if the amp worked with the 12ax7's in their place. I'm new and don't know these things so I ask. Thanks again.
Old 16th September 2007, 11:30 AM   #5
Ty_Bower's Avatar
It's good to ask questions. You can learn a lot about the way tubes work.
Here's a page where I like to go to look for the data sheets on a particular tube:
http://tdsl.duncanamps.com/tubesearch.php
You'll probably want to figure out whether your Bogen is single-ended or push-pull. If it's push-pull, you'll need to understand the different types of phase splitters. There's a bunch of good links in the "On Line Tube Learning for newbies..." thread. I like to read here for an explanation of phase splitters. He also has descriptions of various other tube circuits:
http://www.freewebs.com/valvewizard/index.html
Old 16th September 2007, 09:51 PM   #6
m6tt is offline m6tt  United States
well...actually, sometimes it does _work_, just not very well. I wouldn't use a 12ax7 you were particularly attached to. Even better might be a medium mu tube like an at7 or an ay7...in the long run you will want to determine (hopefully from a schematic) what that tube was doing and why they needed a dissimilar triode there. You will want to change some resistors if you want the tubes to last and sound good. I'd say just order a $12 soviet 12dw7 off the internet.
Old 17th September 2007, 07:55 PM   #7
Hi BlindBrett; noobie here. The 7247 is a disimilar triode; like a 12AX7 as a twin triode but the second 1/2 of the tube is built to dissipate considerably more plate voltage than the first half which, in nearly every other respect, is like a 12AX7. It's possible to use a 7247 in the place of a 12AX7 but not the other way around.
One common application for the 7247 is the driver stage of a guitar amp; the last tube 'feeding' the output tubes. Typical plate resistors for 12AX7s are 100K to 150K ohms; plate resistors for the 7247, particularly the 2nd stage, can be as low as 15K ohms at 2 watts.
if you put a 12AX7 where a 7247 is designed, its useful life will be shorten, performance compromised, and present some risk to your equipment.
Good luck with your project!
12ax7 nigelwright7557 Tubes / Valves 6 1st June 2008 02:54 PM
12dw7 to 12ax7 conversion? m6tt Tubes / Valves 4 17th August 2007 01:33 AM
Lower voltage Dynaco ST35 for 6P14P // 7247 replacement methar Tubes / Valves 6 8th August 2007 04:55 PM
12AX7 how many is enough? Sambeaux Tubes / Valves 19 23rd March 2007 07:31 PM
12ax7 Matthewong Tubes / Valves 0 12th June 2005 04:54 PM
Page generated in 0.10466 seconds (78.15% PHP - 21.85% MySQL) with 10 queries
