| diyAudio Sponsor | ||
#2 |
It would if you pull the first tube.
Otherwise the Rp of the lower triode + Cathode Resistor of the lower triode will "swamp" the 1 Meg Resistor. Think Zout vs. 1 meg voltage divider. Doug I was looking at the other tube. Same principal applies to the output.
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well) Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus |
#3 |
I would say yes and no.
The noise is injected into the output, at 1/2 the magnitude of ripple, and at a 500K source impedance. The musical content, however, is also injected into the output, at a much higher signal level, and a much lower source impedance. The end result is that at the source impedances involved, the injected noise is benign to nonexistent. |
#4 |
So...given a "noisy" CLCLC PSU with some B+ fluctuation due to poor wall power, the likelihood that the Low Frequency B+ noise is being injected into the outputs at this point is very low, correct?
| Aikido question | kacernator | Tubes / Valves | 6 | 22nd April 2008 11:40 AM |
| Adding Subwoofer output to Aikido preamp circuit | dr._sleep | Tubes / Valves | 5 | 13th November 2007 04:18 PM |
| Aikido Attenuator kit question | talaerts | Tubes / Valves | 2 | 9th January 2007 10:12 PM |
| Aikido question | SteveA | Tubes / Valves | 10 | 20th November 2006 08:30 PM |
| Replacing cathode resistors of Aikido 1st stage (or other SRPP circuit) with chokes | snoopyma | Tubes / Valves | 1 | 31st July 2006 05:21 PM |
| Page generated in 0.07465 seconds (69.64% PHP - 30.36% MySQL) with 10 queries |
