diyAudio Sponsor
Old 14th September 2007, 09:39 PM   #1
feniks is offline feniks  Serbia
Default 6sl7gt preamp
I need schema for preamp with 6sl7gt to drive el84.Thanks to all.
Old 16th September 2007, 03:19 AM   #2
Miles Prower's Avatar
Default Re: 6sl7gt preamp
That's asking a lot of a 6SL7. The 6SL7 is a high gain, low current, low g(m) type that doesn't drive power finals very well. Best to add a driver of some sort there.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 16th September 2007, 03:41 AM   #3
Geek's Avatar
6SL7 can drive EL84 OK if the EL84 is running pentode mode and class-A. But don't ask for super linearity without a NFB loop.
Old 16th September 2007, 04:34 AM   #4
dsavitsk's Avatar
Or you could use a step down transformer.
http://www.ecpaudio.com
Old 16th September 2007, 07:48 AM   #5
ok.Thanks for help.
Old 16th September 2007, 08:52 AM   #6
Colt45 is offline Colt45  Serbia
Send a message via ICQ to Colt45
6SL7 will drive a SE EL84 piece of cake. EL84 is super easy to drive.
not sure why you'd need that much gain though.
Old 16th September 2007, 12:10 PM   #7
Just for experiment,nothing special.
Old 16th September 2007, 12:45 PM   #8
Dave Cigna's Avatar
a preamp?
What do you plan to connect to the input and output?
January 20, 2009: Bush's last day
Old 16th September 2007, 10:35 PM   #9
kevinkr's Avatar
6SL7 in srpp will drive a triode or pentode/UL connected EL84 or even an EL34 quite effectively. Take a look at my old 45 SE design for an example. (This amplifier was recently gifted back to me after an absence of several years when its new owner decided he needed to downsize. It still sounds good despite the limitations mentioned in the article.)
www.kta-hifi.net
6SL7 or 6SL7GT for broken Tubalizer Sonusthree Tubes / Valves 105 8th October 2010 05:16 PM
Page generated in 0.08179 seconds (77.11% PHP - 22.89% MySQL) with 10 queries
