diyAudio Sponsor
Old 14th September 2007, 09:15 AM   #1
WE91 is offline WE91  Norway
Question met. MKP in oil capacitors for PSU?
Hi!
I'm wondering about types of metalized polypropylene in oil capacitors to use in my powersupply.
I've found that three manufacturers are commonly used and that there are some controversy about which is the "best".
There have been some hype for some time on the ASC motorrun ones. ASC has now made the blue-line serie as an answer to this demand.
General Electric makes their "general purpose" range that includes the 660VAC line of Gem III series.
Aerovox (US) makes two series that are compatible: The type H and the Aero met II M-series motorrun.
What is your opinion?
Have anyone experience with using several of these - and can compare?
Are there other such type capacitors/brands that needs to be mentioned?
Is it possible to say if any of these is "better" than the other?
Looking very much forward to your input and reading about your experience.
Best Regards
Aril
Yoda: "May the Force be with You"
Acoustic design: www.fmdesign.com Check out the Griffin loudspeakers!
Old 14th September 2007, 09:51 AM   #2
Obligato from diyhifisupply would be another option.
Old 14th September 2007, 10:49 AM   #3
Thank you 'andRookie'!
I forgot to mention the Obligato's!
Are they metalized MKP in oil - or some other oil-filled type?
Aril
Old 16th September 2007, 01:43 PM   #4
- No one that knows, have heard or tried anything?
- I only know what others have reported on other sites about comparisons and experience. I see that some have reported oscillation with the ASC motorrun caps in PSU ...
I haven't seen any report the same with GE's or Aerovox' - and what about the obligato's?
The general concensus seem to be that this type of caps in a PSU is far superior to all(?) other types ...
Anyone to comment?
Aril
what is the difference between silver mica capacitors and ceramic capacitors ?? prorms Solid State 1 6th May 2008 12:38 PM
Continental Capacitors' "Type-A" oil-filled capacitors? radical Parts 0 21st October 2004 08:39 PM
Oil capacitors Praudio Swap Meet 3 7th October 2003 03:00 AM
capacitors: panasonic FC vs elna RJH vs rubycon ZA capacitors costiss Parts 11 30th January 2003 09:32 PM
differences between computer grade capacitors and small can capacitors LBHajdu Pass Labs 0 22nd February 2002 01:29 AM
Page generated in 0.08059 seconds (70.78% PHP - 29.22% MySQL) with 10 queries
