up-to-date El Cheapo schematic
Old 13th March 2015, 10:11 PM   #21
Eli Duttman is offline Eli Duttman  United States
A 6V6 family tube was desired for the "finals". The 12AQ5 was settled on, for its low price. Any 6V6 family tube works with the parts values shown in the schematic.
The B- rail could have been quite a bit "shorter". What was settled on came (you guessed it) from cost considerations. The fact that the B- supply is technically nice is a bonus.
As for "fixed" bias versions of the basic topology, refer to Poindexter's "Musical Machine". Poinz was 1st with this style of 2 stage amp and MUCH was learned from his efforts. The "Musical Machine" is an all out, cost be damned, assault on performance. "El Cheapo" is a budget project that performs far better than the money spent suggests would happen. While inexpensive, the PSU is anything but cheap.
Eli D.
Old 13th March 2015, 10:41 PM   #22
Jim McShane is offline Jim McShane  United States
Originally Posted by Jeff Yourison View Post
All the small components are available from Jim McShane, and the trafos and such can be ordered from online electronics vendors.) Jim's page for the El Cheapo is here:
http://pages.prodigy.net/jimmcshane/elcheapo.htm
Actually my page is www.mcshanedesign.net/elcheapo.htm, the old link Jeff posted is dead.
Old 14th March 2015, 05:21 PM   #23
jdrouin is offline jdrouin  United States
How many watts per channel does a stock El Cheapo put out (say, with Edcor transformers)?
Old 14th March 2015, 06:13 PM   #24
vinylkid58 is offline vinylkid58  Canada
vinylkid58's Avatar
~Ten, AFAIK.
jeff
Old 14th March 2015, 07:36 PM   #25
Approx. 6 WPC for triode and 12 WPC for UL. Some variation will occur depending on B+ rail voltage and selected O/P "iron".
Dynaclone Z565s are the "Gold Standard" for O/P trafos, in an "El Cheapo". Edcor's CXPP25-MS-8K is certainly hefty enough for UL mode. Stick strictly to triode mode, when low cost guitar amp "iron" is used.
Eli D.
Old 14th March 2015, 08:00 PM   #26
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
Our variation on El Cheapo uses triode wired EL84 and runs in Class A. 3.2W at clipping and a fantastic sounding amp.
Eli, i'll be happy to update the drawing but i can't do it until i resolve some issues with my CAD software.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 14th March 2015, 08:46 PM   #27
Dave,
If another Scott "donor" ends up on your doorstep, try 6CM6s as the "finals". The 6CM6 is a Noval based member of the 6V6 family.
Eli D.
Old 14th March 2015, 08:55 PM   #28
tomlang is offline tomlang  United States
tomlang's Avatar
Is there any "simplification" that can be done to this? I.e. utilize a LM334 and skip the negative supply for the LTP as I show in post #20?
Old 14th March 2015, 09:12 PM   #29
AFAIK, it will NOT work, without the B- rail.
Eli D.
Old 31st October 2017, 08:08 PM   #30
crazyfrog is offline crazyfrog  Canada
Default Sorry...
I didn't want to bring back to life an old thread but I had to ask: did someone build an El Cheapo "on steroids" ? With EL84m or 6P14P-ev , higher voltage, fixed bias and MOSFET buffer (ZVN0545A, FQPF2N80...) between LTP and OT ?
If this is the case, is the schematic very different from post 20?
Pierre
up-to-date El Cheapo schematicHide this!Advertise here!
GEC date codes EC8010 Tubes / Valves 10 13th July 2018 04:50 AM
Up to date PIC programming TroelsM Everything Else 4 6th May 2009 08:54 PM
Look At The Date Of Postings i4gotmyid Swap Meet 0 22nd February 2008 02:35 PM
Need easy to use schematic program thats up to date ifrythings Everything Else 1 12th April 2006 09:50 PM
Anyone know the date code on these? K-amps Solid State 8 23rd February 2005 08:20 PM
