diyAudio Sponsor
Old 10th September 2007, 09:47 PM   #1
awedio is offline awedio  United States
awedio's Avatar
Default Tube-based CCS- 0.2uF cap OK?
Everywhere I've seen a tube- (triode-) based constant current source schematic, the value of the grid bypass cap is ALWAYS 0.1 uF. I have never seen this value explained or calculated...
So, can someone explain what happens if the value is doubled? (Yes I have a bunch of 0.22uF caps!!!) I have a feeling that I could try it out to see, but probably not hear or measure a difference. So does anyone know how to explain how this value is determined?
Thanks.
"Where is my mind? Where is my mind? Wheeere is myyy mind? Waaay out, in the water, see it swimmin'..." Black Francis
Old 11th September 2007, 07:48 AM   #2
Geek's Avatar
Go ahead and use the 0.22uF ... it's an arbitrary value just to keep the thing from oscillating.
Too low C, audible to supersonic oscillation and/or noisy. Too high C, risk of motorboating (depending on tube).
But you should know that triodes make bad CCS', because their Rp is so low compared to a pentode. But if you have a lonely triode section looking for something to do, it's better than a plain R, I guess
Cheers!
SET with tube-based CCS??? awedio Tubes / Valves 14 17th May 2007 11:32 PM
Tube based mic preamp mixer amperex Instruments and Amps 7 22nd February 2006 09:06 PM
Wanted: Dac pcb for tda1541a (non tube based) ash_dac Swap Meet 6 7th January 2006 05:44 PM
tube based CCS GAK Tubes / Valves 9 12th February 2004 04:58 AM
Page generated in 0.08755 seconds (56.79% PHP - 43.21% MySQL) with 10 queries
