Audio Research SP9 guilty of screeching sounds! - diyAudio
Old 6th February 2003, 10:47 PM   #1
Eric116 is offline Eric116  United States
Default Audio Research SP9 guilty of screeching sounds!
Hi all,
First of all, please pardon me of my ignorance in all tube matters, as my understanding and manipulation of the Audio Research SP9 Mark II preamplifier that sits in my living room has to this date been limited to turning buttons and flipping switches located on the front of this device.
However, thanks to the help of the speakers people (the "other" forum), I have come to the conclusion that the preamplifier is responsible for screeeeching sounds when the volume is turned up or down As background, the preamplifier is linked to a McCormack Power Drive DNA 0.5 amplifier, and finally to a pair of B&W Nautilus 804 speakers. Current hypotheses on the cause of this problem are (1) the volume knob and (2) the tubes.
Has anyone encountered a similar issue? Is this an "easy" fix or is it a major project? Also, any input on troubleshooting would be greatly appreciated!
Thanks for your help!
Eric
Old 6th February 2003, 11:47 PM   #2
SY's Avatar
If this is happening when you *change* the volume setting, I'd start the troubleshooting process by looking at offset voltages, especially if this is isolated to one channel. And stick a scope on the power supply rails to see if something is oscillating.
Old 6th February 2003, 11:53 PM   #3
diyAudio Senior Member
fdegrove's Avatar
Default SP9.
A tube has its' voltage to cathode insulation surpassed and has gone south.
Typical for this circuit really...
Sillly design if you ask me,
Frank
Old 3rd January 2007, 09:46 AM   #4
Default ok!
Hi ! You sent me circuit 6h30 (6n6p) please?
I want it! thank you!
Audio Research D-90 rudy129 Tubes / Valves 4 11th June 2010 01:19 PM
Audio Research lawbadman Tubes / Valves 26 2nd November 2007 03:49 PM
Audio Research SP6 E PIERRICK Tubes / Valves 1 26th November 2006 10:03 AM
Ground loop ain't always the guilty one Stabist Pass Labs 1 16th September 2004 11:01 PM
audio research sp6/8--better than sp9? croft Parts 8 16th November 2002 01:25 AM
Copyright 1999-2017 diyAudio
