diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   PSU problem (http://www.diyaudio.com/forums/tubes-valves/108247-psu-problem.html)
tyor 10th September 2007 06:00 AM
PSU problem
2 Attachment(s)
I am building a psu for a 250TH SE amp. I have a transformer that gives 1040v ac Planning tu use hybrid rectifier. (tubes and SS) So I dont have to use 4 heater vindings. But kan I conect the fillaments on the pic in serie? The transformer has 1x5v for heaters and i plan to use 866 tubes ratet for 2.5v fillament.
Colt45 10th September 2007 07:04 AM
should be ok, but make sure to take B+ from pin 4 ( if i remember, the one with the shield). so tie both pin 4 together.
better to use a 5v CT trafo though, incase slight unbalance in heater current, probably.
I don't know if i'd bother with 866's, they look nice but they're a pain in the ***.
I don't really see the point of this half silicon ****.. all or nothing! :rolleyes:
tyor 10th September 2007 07:13 AM
I planned to use 4x866 but I have to use 3 seperate fillament vindings that can stand the high voltage. In this way I can use the one fillament vinding on the transformator, and still have the blue light :)
Colt45 10th September 2007 09:36 AM
I'm not sure how you'll switch this then, with integrated 5v winding. You'll have to switch the HT... because 866 needs a long warmup.
Dave Cigna 10th September 2007 11:44 AM
Series filaments on 5V will work fine, but listen to Colt45. MV rectifiers need to heat up for half a minute before B+ is applied. You could use a separate filament supply with a separate power switch. Some people have used a single transformer and put a standby switch in one of the HV secondary leads, though 1000VAC on a switch scares me. A solution that I like is to put a single damper diode in series after the bridge. It takes 30 seconds or so to warm up, then provides a soft start. You can put a switch across the damper to short it once everything is warmed up and running.
tyor 10th September 2007 06:40 PM
Thanks for al the tips. But I have decided to revind a toriod trafo to 2.5V sek.
refference 11th September 2007 03:00 AM
" A solution that I like is to put a single damper diode in series after the bridge. It takes 30 seconds or so to warm up, then provides a soft start. You can put a switch across the damper to short it once everything is warmed up and running. "
Hi Dave ,
Wow !!!! Really a very , very good idea , congratulations .
I had never thought about this very simple solution !!!
Regards ,
Carlos
Copyright 1999-2017 diyAudio
