Humm
Humm
Old 6th February 2003, 06:59 PM   #1
whatgive is offline whatgive  United States
Send a message via AIM to whatgive Send a message via MSN to whatgive Send a message via Yahoo to whatgive
Default Humm
My vintage tube amp has a 500K pot to adjust the volume. It hums when I turn volume past 10'oclock. Any ideas what the problem maybe. It does not hum at all when volume control is at 9'oclock or less.
whatgive
Old 6th February 2003, 07:10 PM   #2
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Default HUMMM...
Most likely it hums all the time,you may just not hear it at lower volume settings.
The taper of the old 500K may well have a different attenution curve compared to what is commonly used nowadays.
The hum may be a ground loop or some injected hum from AC fed heaters.
It is also possible that a filtercap has dried up and lets the ripple through.
Frank
Old 7th February 2003, 02:02 AM   #3
Ah, thanks for the tips - I will do a check up on those that you've mentioned.
whatgive
Old 7th February 2003, 04:03 PM   #4
ashok is offline ashok
ashok's Avatar
Humm
Default HF problems?
Just a small warning. I once had a hum develop in my power amp when the volume control went past a point. It turned out to b eHF oscillation - I could see it on the scope. WHile you cannot hear the HF ( RF) its effects filter down ! Check to see if your power transistors are heating up suddenly . The RF is usually of very low amplitude.
Just a word of caution. In your case it might be just a hum loop ----- Hmmmm.
Cheers.
AM
Old 8th February 2003, 04:24 AM   #5
Default OK - I will check on that too.
Many thanks.
whatgive
HummHide this!Advertise here!
What's causing that #$%&@$ humm?? sachi Chip Amps 10 9th February 2006 01:29 PM
Humm in my preamp... Bryan Tubes / Valves 5 19th November 2005 01:08 PM
System humm Flemming J P Everything Else 3 2nd December 2003 07:52 PM
Humm...first post :) Sch3mat1c Car Audio 3 26th February 2003 09:10 AM
humm in sds headphone amp. rwagter Headphone Systems 4 19th August 2002 04:13 PM
Copyright ©1999-2017 diyAudio
