diyAudio Sponsor
Old 7th September 2007, 08:34 PM   #1
feniks is offline feniks  Serbia
Default 835 amp
Amp schema for 835 tube.My english is bad.Help please.
Old 7th September 2007, 10:13 PM   #2
Fuling is offline Fuling  Sweden
Here is some sort of datasheet for 835:
http://frank.pocnet.net/sheets/049/8/835.pdf
It states that 835 is similar to the well known 211 except the inter electrode capacitances, so search for schematics of amps that uses 211 and you will find alot. Beware of the high voltages (1kV and up) present in this kind of amps.
http://www2u.biglobe.ne.jp/~tossie/OT-211-J.html
http://www.lunarnetbbs.org/audio/myp...myprojects.htm
Again: These voltages are absolutely deadly, donīt attempt to build anything like this unless you have a lot of experience in building tube and HV equipment.
Best regards,
Daniel
Old 7th September 2007, 10:43 PM   #3
Thanks.
Page generated in 0.06819 seconds (69.87% PHP - 30.13% MySQL) with 9 queries
Copyright Đ1999-2012 diyAudio
