diyAudio Sponsor
Old 6th September 2007, 04:45 PM   #1
sgerus is offline sgerus  United States
Default Anode Cap Question
Sorry if this is a stupid question. What is the best way to fasten the cable to one of these Anode Caps? (see attachment)
I’m using a shielded cable, with the shield connected at the input only. I cut back the shielding at the cap end, and covered with shrink wrap tubing. The center wire is very thin, so for now I just pressed it into the top of the cap.
This is a temporary solution. Whats the right way to do this?
Old 6th September 2007, 04:47 PM   #2
with the attachment this time?
Old 6th September 2007, 06:17 PM   #3
tyor is offline tyor  Norway
I use to solder the cable to the cap
Old 6th September 2007, 08:14 PM   #4
KaDe is offline KaDe  Germany
KaDe's Avatar
I use 22 AWG ( AWM STYLE 3239 ) 150°C 20KVDC wires.
Old 7th September 2007, 07:11 AM   #5
oshifis is offline oshifis  Hungary
I use 18 AWG silver wire in teflon tube sleeve.
Old 7th September 2007, 04:48 PM   #6
kevinkr's Avatar
You didn't mention the tube type and whether the top cap on this tube is grid (suspected from your description of wire used) or the plate.
Insulation and safety requirements will be quite different depending on use.
In any event the wire should be soldered to the connector and not the tube cap. (Although in a pinch I have carefully soldered directly to the tube's cap.)
www.kta-hifi.net
Old 7th September 2007, 05:00 PM   #7
It's a 6j7g pentode, the top cap is the grid.
I’m surprised to see from to of the replies that they did not use a shielded wire.
I will definitely solder the wire to this cap.
Thanks for the help.
Anode Follower yagas Tubes / Valves 19 20th November 2010 04:35 PM
Anode chokes DIY? dshortt9 Tubes / Valves 5 28th February 2009 03:22 AM
Anode stoppers Shoog Tubes / Valves 4 12th June 2007 06:14 PM
Question about direct coupling a anode follower into a cathode follower. G Tubes / Valves 45 29th July 2004 06:47 PM
Anode choke question tõnu Tubes / Valves 11 29th April 2002 08:56 AM
Page generated in 0.08873 seconds (73.74% PHP - 26.26% MySQL) with 11 queries
