diyAudio Sponsor
Old 5th September 2007, 11:12 PM   #1
elementx's Avatar
Default what pins to use solid rectifier for 5Y3
My princeton tube amp needs a new 5Y3 rectifier tube. I have tons of solid state bridge rectifiers, I'd like to use one in place of the tube.
Anyone know what pins are which for the 5Y3? It should just be 2 pins for AC two for DC, right?
Old 5th September 2007, 11:25 PM   #2
Get a new 5Y3 pronto. You can't use a bridge rectifier. The topology is full wave CT. Replacing the 5Y3 with a pair of SS diodes could result in the signal tubes being overvoltaged. The forward drop in a 5Y3 is large.
Eli D.
Old 6th September 2007, 01:38 AM   #3
elementx's Avatar
Hmm I guess I never thought of that, a solid state rect. would be a lot more efficient...
What's the deal then with the solid state replacements, they load down the voltage to a comparable level or something?
Old 6th September 2007, 03:07 AM   #4
kevinkr's Avatar
Unfortunately, not usually. I've seen plenty of fried electrolytics in amps where these were used because they get over-voltaged until the tubes in the output stage warm up enough to draw sufficient current to drop the voltage.
Another thing is that substituting a solid state rectifier for that 5Y3 is going to change the tone and attack/sustain characteristics of your amplifier in ways you probably won't like much.
www.kta-hifi.net
Old 6th September 2007, 03:13 AM   #5
kevinkr's Avatar
In the case of the bridge rectifier (adequate PIV assumed) it can be used as a full wave center tapped rectifier simply by ignoring the negative pin. (Leave it unconnected.) You can also do all sorts of other interesting and sometimes useful things with bridges if you look closely enough.
--- However for all the reasons ELI and I mentioned in previous posts I would not use any SS rectifier in this amplifier. ---
www.kta-hifi.net
Old 6th September 2007, 09:12 PM   #6
If you really want to go solid state, go to webervst and get a copper-cap. He would be the only one I would trust for your Princeton.
But, a brand spanking new 5Y3 is is $6.50 at findatube, and you would probably be set for the next 50 years. That is what I would do.
-e
Bridge rectifier vs Full wave rectifier hilbert_mostert Tubes / Valves 4 28th April 2009 08:26 PM
Tube rectifier to Solid state Diodes exchange WALTER BURKHARD Tubes / Valves 2 20th July 2007 05:41 AM
Leak Stereo 20 - solid state rectifier? bremen nacht Tubes / Valves 17 7th July 2005 05:41 AM
Anybody heard about Tarzian Silicon Rectifier for Tube Rectifier Replacement? zxx123 Tubes / Valves 4 21st February 2005 04:02 AM
Page generated in 0.07974 seconds (75.48% PHP - 24.52% MySQL) with 10 queries
