| diyAudio Sponsor | ||
#21 |
I don't think this is single ended.
#22 |
Is it single ended or pp? Here is a comment on this (solid state example though)
http://www.tcaas.btinternet.co.uk/jlhoutput.pdf The rail voltage is single for sure
Daisy Bell |
#23 |
"Is it single ended or pp?"
With matched current drives, as in the JLH output, or with matched voltage drives, as in the bootstrapped drive (Yvesm schematic), the even harmonic distortion products will cancel (for matched output devices), so they are obviously P-P. Don
Ohms Law V = I R |
#24 |
It is a pseudo push-pull design. At around 1969 it was difficult to make complementary transistors, so they designed (iron or no-iron) pseudo-pp amps, no need for expensive transistor-couples (and matching) Philips and others came with some of those designs.
PP indeed eleminates 2nd order harmonics. The use of a triode in the first stage creates some even harmonics, all together the amp could sound very neutral due to the combination of "even" & "odd" stages. But i am unaware what the bootstrap will do to the harmonic distorsion., (bootstrap = positive feedback)
Daisy Bell |
#25 |
The splitter bootstrap guarantees equal grid to cathode drive voltage on the top output tube. Since it references the equal voltage drop on the top 82K (versus the bottom 82K) splitter resistor to the top tube's cathode (which the bottom drive already does too).
Since the splitter bootstrap is not increasing the top grid drive versus the bottom grid drive, it should not be creating any additional distortion here. Really just has the same effect as one would get using an interstage transformer with two floating secondaries. (Remind me not to buy any interstage transformers, how stupid!) Don
Ohms Law V = I R |
#26 |
Talking about interstage transformeres: had 2 identical ones with special mu core, one i demolisched as study-object, i am now sorry i did.
Did some thinking to add a cap and a autotransformer, not easy with the bootstrap.
Daisy Bell |
#27 |
Daisy Bell |
#28 |
Daisy Bell |
| "Mighty Mite" Single Ended Amplifier | wrenchone | Tubes / Valves | 13 | 20th October 2008 04:57 AM |
| glass audio 1995 "Single Ended Glory" | habsrock93 | Tubes / Valves | 3 | 22nd June 2008 02:10 AM |
| Building a high quality gainclone toroid coupling transformer with "tubeness" winding | ionomolo | Chip Amps | 16 | 13th February 2008 01:20 PM |
| FS: Homebuilt "Aikido" 2A3 single ended triode amp | jim_vt | Swap Meet | 11 | 21st January 2006 03:38 PM |
| Using Telefunken "Tank" transfomers for a single ended el84 amp? | ark | Tubes / Valves | 13 | 8th March 2004 11:32 PM |
| Page generated in 0.09594 seconds (77.81% PHP - 22.19% MySQL) with 10 queries |
