| diyAudio Sponsor | ||
On his Aikido PCB, Jim Broskie has designed pads for two stets of output caps. He suggests that this would allow for different flavours of caps, or different values of the same flavour.
These two sets of caps can be switched using a selector. So, what kind of selector would be better - make before break, or break before make? And....has anyone found a really classy-looking switch/knob that would work? Thank-you in advance, Charlie |
#2 |
I would use a make-before-break switch to help prevent any popping noises. And I prefer ceramic rotory types with "Alco" solid aluminum knobs of which there are many styles.
Classy? Too subjective. One man's class is another man's funk. edit: I received my Aikido boards a couple of weeks ago and was impressed with their quality. My winter project.
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University |
#3 |
Another way to minimize popping when switching is to make sure each cap output has a pull down resistor, if it doesn't already on the Aikido board.
For knobs, a lot of times I go to a music store. Some stores carry a big assortment of custom knobs for guitars and basses that can work good for diy amps as well. |
| source selector / volume hum in Aikido | cbutterworth | Tubes / Valves | 1 | 28th March 2007 07:34 AM |
| Selector switch | Rnickl | Parts | 8 | 29th January 2006 07:12 PM |
| Selector switch on a T-amp? | triodesteve | Class D | 1 | 31st December 2005 05:04 AM |
| pre-amp selector switch | bonz | Solid State | 2 | 21st November 2005 04:37 AM |
| Do I need an Output Selector Switch | DC Dave | Chip Amps | 0 | 22nd April 2005 03:31 AM |
| Page generated in 0.08066 seconds (72.72% PHP - 27.28% MySQL) with 10 queries |
