diyAudio Sponsor
Old 1st September 2007, 11:56 PM   #1
prorms is offline prorms  United States
Send a message via ICQ to prorms
Default need expert help presence control
do you know of any other presence control beside the one on this shematic????
Old 2nd September 2007, 12:12 AM   #2
aletheian's Avatar
For some reason, your image cannot be enlarged when clicked upon...
Heghlu'meH QaQ jajvam!
Old 2nd September 2007, 01:16 AM   #3
Default ....
Old 2nd September 2007, 01:49 AM   #4
Obviously you are seeking a different type of presence control. The only application I know of for this type of EQ is in guitar amps, and in those the presence removes negative feedback in the treble to give a boost in the treble in a different manner than a regular tone control circuit. I guess it's reason for existance is increased treble with good dampening at the bass end, and less dampening factor at treble??? The circuits you posted does that, reduces the high frequency NFB.
What kind of different way do you want to achieve this, and why?
Old 2nd September 2007, 01:51 AM   #5
aletheian's Avatar
Are you looking for boost or cut? This looks like a high shelving filter either for use in a power amp global feedback loop to boost highs or in a preamp to cut them. What is the topology of the amp?
Old 2nd September 2007, 04:00 PM   #6
I am looking for any type of presence control
boost or cut or both
I need them to make easy to control the final stages of 2band eq
or 3 band eq
the more i have to choose form the better the choices
Old 3rd September 2007, 12:04 AM   #7
aletheian's Avatar
You are going to have to be much ,much more specific. We can definately help you out but not unless we know what we are helping with since there are 1,000,000 ways to do it, but without know int the topology, what you are feeding, the Zin the Zout, active or passive, which frequencies you are interested in, how much boost or cut, if you are about phase response, if you want a shelf or a pass filter etc etc etc.
Old 3rd September 2007, 12:25 AM   #8
boost and cut around 300hz - 500hz
or something that will completely cut singal out but will still boost the treble or bass side
Old 3rd September 2007, 12:28 AM   #9
kevinkr's Avatar
Is this thing for hifi or guitar use? If guitar or MI go to Duncan amps website and download his tone stack designer software.
www.kta-hifi.net
Old 3rd September 2007, 12:56 AM   #10
what would be good hifi choose??//
Presence control on a SE ? vlljpior Tubes / Valves 8 10th October 2005 03:43 PM
presence control vlljpior Tubes / Valves 0 8th July 2005 07:03 PM
Page generated in 0.09661 seconds (76.59% PHP - 23.41% MySQL) with 11 queries
