diyAudio Sponsor
Old 29th August 2007, 07:03 PM   #1
Default your opinion needed.......
can someone tell mi something about this amp? did someone bought it? thanks in advance.
danny
p.s.: will work together with OB's?
http://www.spectrumaudio.de/roehre.html
(the first two)
Old 29th August 2007, 10:37 PM   #2
diyAudio Moderator Emeritus
ray_moth's Avatar
Prices seem reasonable but I don't know about the quality. At least they're not making extravagant performance claims!
Here is a Babelfish translation for the first two amps:
First amp
Outstanding sounding tube amplifier
after a connection diagram of the 50's
at a reasonable price.
Power output: 2 x 3.5 Watts of class A
Range with 1 Watt: 25 cycles per second - 30 kHz (-1dB)
Distortion with 1 Watt/3.5 Watts: <1% / <5%
S/R relationship (signal-to-noise ratio): > 70dB
Feed impedance: 100 Kilo ohms
Output impedance: 8 ohms
Input level: 500 mVs
Capacity: maximally 50 Watts
Tube assembly: 2 x EL84, 1 x ECC83
Dimensions: B*T*H=250*165*160 mm
Weight: 5 kg
_________________________________________________
Second amp
High-quality, high performance tube amplifier
at a very attractive price.
Power output: 2 x 35 Watts
Range: 20 cycles per second - 40 kHz (+-3dB)
Distortion THD: <1%
S/N relationship (signal-to-noise ratio): > 88 railways
Output impedance: 4 and 8 ohms
Input level: 600 mVs
Capacity: maximally 250 Watts
Tube assembly: 4 x EL34, 2 x 6F2 (ECF82/6U8)
Dimensions: B*T*H=400*260*190 mm
Weight: 13 kg
Also as VR-80E chrome mono output stage with 80 Watts
for 495, - euro available.
Old 30th August 2007, 05:23 PM   #3
ray_moth thanks, i speak 5 languages, and german is one of them, so i didnt need translation )))) but thanks for help.
what i ment, i'm looking for some tube amp that wont destroy my bank account ))
and no, i can't build one myself ))) oh god no, that would be IL TERIBILE !!!!!!!!!!
max i want to spend is cca £200 - £300 preamp (tube or standard)
and £400 - £600 for power amp/monoblocks ...... its should be for OB's fullrange driver only.for the sub something different.
thank you all.
danny
Old 30th August 2007, 10:53 PM   #4
ray_moth's Avatar
Never mind, it might help some others to understand I hope someone who knows these products can advise you.
Going for an inexpensive solution, especially if you can't examine and hear the amp first, carries the risk of having to fix it up yourself until you're happy with it. You might need to carry out some selective component replacement or rewiring. If you don't want to do that kind of work or incur additional costs, you need to bear this in mind.
behringer Ultramatch Pro SRC2496 MAX MOD opinion needed lga775 Digital Line Level 1 5th February 2009 08:51 PM
DAC - Opinion needed Faust3D Digital Source 45 20th November 2007 10:25 PM
Omnes audio L8spec - opinion needed barackuda Full Range 3 11th September 2007 11:42 AM
Schematic opinion needed (guitar amp) Trout Tubes / Valves 8 2nd March 2006 03:35 AM
Opinion on those electrolytics needed Peter Daniel Parts 3 25th November 2003 05:12 PM
Page generated in 0.07604 seconds (76.00% PHP - 24.00% MySQL) with 10 queries
