| diyAudio Sponsor | ||
I wonder if i use a 8ohm speaker on the 4ohm tapping of a OPT that have 2.5k pri. wil that give me 5k pri impedance?
#2 |
Yes.
Life is hard - Then you die. |
#3 |
yes, it will.
emission over emittor |
#4 |
thanks.
#5 |
Hi!
Can a PP opt be used as a SE opt ? if so, use one-side-to-centretap or use the whole primairy ? I got a PP opt Ra-a of 1K7, how much would one side be ? cheers, Empee
In the end, all is good If it's not good, it's not the end |
#6 |
Hi Empee,
yes, but without DC in the primary. Use both sides of the primary connected in series. Regards Andreas P.S. using only one side you'll get 1/4 of the inductance |
#7 |
how do you mean that, without DC in the primairy ?
and just to be sure: In series, so leave the centretap unconnected. Primairy remains 1K7. If 8 ohm speaker used on 3 ohm tap primairy acts as 5.1K EL34SE ?
#8 | ||
Regards Andreas |
| What impedance? | jaya000 | Multi-Way | 11 | 21st November 2008 07:04 AM |
| Impedance rate VS impedance stability | TomatoBangBang | Tubes / Valves | 6 | 4th September 2008 10:46 PM |
| Hi Vi SD1.1 impedance | guitarded | Multi-Way | 0 | 3rd February 2008 08:35 AM |
| Impedance and SPL.. | TroelsM | Multi-Way | 5 | 26th September 2005 12:52 PM |
| Need help understanding transformer impedance ratios and impedance matching | percy | Tubes / Valves | 5 | 28th February 2005 08:35 PM |
| Page generated in 0.08473 seconds (76.67% PHP - 23.33% MySQL) with 10 queries |
