diyAudio Sponsor
Old 28th August 2007, 08:07 AM   #1
poynton is offline poynton  United Kingdom
Magneto the Gravity Man
poynton's Avatar
Location: A life on the ocean waves when I'm not at home in N. Wales (but I'm not Welsh so no sheep jokes!)
Default 829B, 3E29, QQV03-20 Connector
Anyone have a source for a decent connector for the anode pin of these tubes ?
I have made some from brass sheet but I have seen some very pretty ones on commercial amps.
Andy
Old 28th August 2007, 09:08 AM   #2
Colt45 is offline Colt45  Serbia
Send a message via ICQ to Colt45
Common method is to use a piece of whatever metal, id = that of the 829B's pin, and a small setscrew.
make the od the same size as a common anode cap (1/4", 3/8" etc).. sort of an adaptor rather than a one piece deal.
Old 28th August 2007, 09:28 AM   #3
Geek's Avatar
Or just use "female" pin connectors, like the audio amp manufacturers use for these.
829B Based Amp silverchris Tubes / Valves 11 12th March 2012 10:26 AM
829B as LTP? DrewP Tubes / Valves 10 17th June 2009 07:00 PM
Can I use 4-pin Molex connector as speaker connector? MikeHunt79 Everything Else 5 3rd June 2009 07:21 PM
829B/3E29 datasheet triodemode permagne Tubes / Valves 3 19th December 2004 12:01 PM
Page generated in 0.10510 seconds (54.38% PHP - 45.62% MySQL) with 11 queries
