diyAudio Sponsor
Old 28th August 2007, 11:29 AM   #1
tyor is offline tyor  Norway
Default OPT for 250th Se A2
Hi i am planning to build a SE A2 amp with 250th tubes. I dont know what output transformator I should use. I have been looking at LL1691 from Lundahl http://www.lundahl.se/pdfs/datash/1691.pdf Wil that be a good one?
Old 28th August 2007, 07:21 PM   #2
anybody that have a clue on what trafo to use for a 250th in single ended?
Old 28th August 2007, 07:35 PM   #3
Fuling is offline Fuling  Sweden
Are you asking for a specific brand/model to use or what parameters an OPT should have to match the 250th tube?
Old 28th August 2007, 07:51 PM   #4
The parameter.
But if you know a spesific model that I can use so spit out
Old 28th August 2007, 08:44 PM   #5
The only plate curves I can find for 250th are drawn in "constant current mode" which gives me no hints of a suitable point of operation. A quick google search revealed nothing, but when I say "quick" I mean it. Some info must be available somewhere.
Old 28th August 2007, 09:19 PM   #6
When I asked on a forum 2.5 years ago, I got this answer
1 kvdc 200 mA Gv of +40 would call for an OPT primary of about 4k5, and [if properly implemented] would probably be good for about 60-70 Watts. Assuming we can trust the tube curves, grid current would remain under 25 mA.
and 3-250A4 is the same tube
Old 28th August 2007, 09:25 PM   #7
here are some data for the tube or substitutes
http://www.mif.pg.gda.pl/homepages/f.../t/TB4-800.pdf
http://tdsl.duncanamps.com/pdf/vm076.pdf
http://www.nj7p.org/Tube4.php?tube=3-250A4
Old 29th August 2007, 11:50 AM   #8
Then Hammonds biggest SE OPT should work. It´s 5k 300mA 75W IIRC
Old 30th August 2007, 05:55 PM   #9
gianis is offline gianis  Greece
Default tube
250TH amplifier at 1KV H.T. and 4.5kv primary output transf. about 70 W RMS
Old 31st August 2007, 08:05 AM   #10
Gluca is offline Gluca  Italy
tarmac ripper
Gluca's Avatar
Default UH!? OH!?
Great Job! Congrats. Any other pic or info?
Gianluca
Fred Dieckmann passed his 250th post dice45 Everything Else 9 19th November 2002 03:20 AM
Page generated in 0.11363 seconds (70.73% PHP - 29.27% MySQL) with 11 queries
