| diyAudio Sponsor | ||
Hi, I need to check voltages on my Radford amp... the (British) schematic only has one set of voltages marked, so I'm assuming these apply when using 220V mains. I live in the US and have the transformers wired for 125V. Is there a formula I can apply to the voltages on the schematic to find the correct readings when using 125V AC power?
#2 |
If the transformer is wired for 125V mains, then all the voltages in the amp should be the same (apart from the transformer primary of course).
Best regards, Mikkel C. Simonsen |
#3 |
Ah... really? I guess that makes sense. My Leak Stereo 20 schematic shows two sets of voltages, one for 220V mains, one for 110V, so that's why I expected it on the Radford too.
#4 |
Indeed, all the voltages checked out just about perfectly as marked.
What does it mean in the schematic when it says 350 (at a point which measures 350VDC with a load hooked up), and then 170V in italics next to it? Is the 170V without a load, or something? Sorry for all n00b questions
| MAINS... simple, old style amplifier, plugged into mains electrical outlet (110) | destroyer X | Solid State | 2 | 15th June 2008 02:31 PM |
| measuring hum | woodturner-fran | Tubes / Valves | 16 | 7th February 2007 02:28 AM |
| 5 volt dc 5 amp switch mode schematic from 240ac mains | mikechamboko | Power Supplies | 0 | 15th March 2005 09:14 AM |
| Measuring Le | thatvan | Multi-Way | 6 | 29th October 2004 10:09 PM |
| Measuring fT and hFE? | capslock | Solid State | 6 | 23rd September 2003 03:50 PM |
| Page generated in 0.08507 seconds (69.89% PHP - 30.11% MySQL) with 10 queries |
