diyAudio Sponsor
Old 27th August 2007, 09:04 PM   #1
adalin is offline adalin  Sweden
adalin's Avatar
Default strange tube
Hi
bought some tubes and got a strange fellow in the box
the manufacturer is RADIOAG (~) DSLOEWE
they where big on tubes in the 193x i believe
In the top there is a small chamber, its not connected to the inside of the tube, in the chamber there is what I believe to be oil ?
The inside of the tube is not that big, just alot of glass
What is this? and why the chamber on top?
Tubes 4 ever
Old 28th August 2007, 12:25 AM   #2
astouffer's Avatar
You could try looking around www.r-type.org or www.tubecollector.org and see if theres anything similar. The side chamber might be for mercury, but thats my best guess
Old 28th August 2007, 06:11 PM   #3
Miles Prower's Avatar
Default Re: strange tube
Probably is, from an oil based condensation pump used during pump-down. Oil was cheaper than mercury, and a good deal less potentially dangerous in case the pump imploded. Of course, in those days, they didn't have the ultra low vapour pressure vacuum oils that we have today.
Looks like that was intended to operate as a "cold finger" to condense oil vapours coming from the condensation pump to keep them out of the tube itself.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 28th August 2007, 06:33 PM   #4
adalin's Avatar
Hmm so the oil was just there to get a better vaccum in the tube?
but why? there where tubes made in these days without the oil
Or is this tube some sort of hardvaccum tube, and how old is this tube based on the construction if this is the case?
So if this is correct the little chamber was cooled during sealing creating a underpressure sucking in the oil that was escaping from the pump?
I was misstaken before in one point, its not the anode that leads out o the top, its one of the grids, the tube got two grids, and an extremely thin single heaterwire in the center, no catode.
all in a circular mounting
Its printed BP1100 at the base
Tubes 4 ever
Old 28th August 2007, 08:11 PM   #5
Default Loewe Multivalve
Loewe made a series of multivalve tubes - and I suspect this is one of them.
Sort of the original IC.
Look at Loewe Multi-valves for one example.
They are rare, and quite collectable in the radio world.
You might inquire over at the Tube Collectors Association on Yahoo. It's a very knowledgable group.
- Gary Tube WebStuff
Old 28th August 2007, 09:52 PM   #6
Not really. A mechanical pump can't pull a good enough vacuum for a VT all by itself. It requires the assistance of a condensation pump. This works by creating a vapour barrier between the exhaust manifold and the mechanical pump. Air molecules can pass from the manifold to the mechanical pump side of the barrier, but not go back in the other direction. Molecular drag also plays a secondary role in improving the vacuum. However, some oil vapour will find its way into the exhaust manifold if you don't use a cold trap.
They still use condensation pumps. Although why they didn't use a cold trap on the manifold, instead of on each tube is a strange one indeed.
www.dolphin-hsl.com
strange tube gianis33 Tubes / Valves 19 26th January 2009 12:23 AM
strange tube? E-8128 Electar Tubes / Valves 2 13th January 2009 01:21 PM
strange tube G1 S/5 Mr. Triatic Tubes / Valves 22 6th June 2006 10:42 AM
strange tube gianis Tubes / Valves 10 7th March 2005 10:42 PM
Strange Tube adalin Tubes / Valves 11 14th July 2004 07:30 AM
Page generated in 0.10759 seconds (71.22% PHP - 28.78% MySQL) with 11 queries
