| diyAudio Sponsor | ||
Does anyone know of a way to reduce the gain on this preamp. There used to be internal switches to reduce the gain from 30db to 23db, and that is still to much. I`ve heard about devices that plug into the interconnect between pre and amp to reduce gain. Anybody had any expirience with these. Thanks, NOXO
#2 | |
These mysterious devices of which you speak, they are more commonly known as a pair of resistors ... no? Do you have a schematic you can post? Short of that, you might put a resistor in line with the input before the pot to reduce it's sensitivity a bit.
http://www.ecpaudio.com |
#3 | |
no xo Yes a schematic would be very nice... You can build a simple resistive divider into the inputs as needed. For a tuner or cd player you might use a pair of 10K resistors for a total attenuation of about 6dB. (Excluding the volume control loading effects.) Doing it this way keeps the source impedance low into the pre-amp's internal wiring, reducing the potential for cross-talk and noise pick up prior to the volume control.
www.kta-hifi.net |
#4 |
The inline attenuators I`ve heard of are resistors. And come on you guys, take it easy on a guy that does`nt even know enough to be dangerous. ( Are you laughing at me or with me?) Don`t worry, I can take it. And thanks for your quick replies. I`ll hunt around for a schematic. I know what I would like to accomplish and have no idea how to do it.
#5 | |
| Audible Illusions Dual Mono Preamplifier | edrel sison | Tubes / Valves | 6 | 7th September 2011 10:57 PM |
| Audible Illusions Modulus faulty? | st2_998 | Tubes / Valves | 4 | 25th August 2007 02:20 PM |
| audible illusions dual mono preamp | firecox | Tubes / Valves | 4 | 28th December 2006 08:46 AM |
| input caps in an Audible Illusions M3 | funnyjoe | Digital Source | 0 | 24th October 2004 05:58 AM |
| 60 Hz noise in modified Audible Illusions M2B | mas | Tubes / Valves | 1 | 14th May 2004 03:59 PM |
| Page generated in 0.09167 seconds (75.91% PHP - 24.09% MySQL) with 10 queries |
