| diyAudio Sponsor | ||
custom xformers laying around - ~11lb, M6, 1K p-p - is there anything other than ppp HOT to make an ok "something"? IIRC 2 & 8 ohm taps had the widest small signal bandwidth - might not be enough inductance to put ~8 on 2 (?) spec supposed to be 40H
#3 | |
Yeah, give to Geek for proper disposal But seriously.... Don't underestimate 40H. If you run under the transformer's rated power, you can extend the lows pretty far. Example, I have a 2 watt SET using a transformer rated for 15W at 70Hz. At 2 watts, she goes to 24Hz F3 and 17Hz, F6 Cheers! |
| Cheap sub usable? | dhias | Subwoofers | 1 | 28th May 2009 02:56 AM |
| car amp usable as sub-amp? | DIY_Peter | Multi-Way | 4 | 12th April 2003 05:29 PM |
| Page generated in 0.06721 seconds (66.97% PHP - 33.03% MySQL) with 10 queries |
