| diyAudio Sponsor | ||
This topic has come up before, but I can't find the thread. My newly built phono stage has some kind of low frequency(subsonic) instability/oscillation. It occurs with or without a load.
What are common causes for this? I can post a schematic later if that will help |
#2 |
Nevermind, found the issue. My soldering iron was plugged into the same power strip and it was causing sagging in the mains. It's a temp cycle controlled type.
#3 |
RIP
Great catch. That could have turned frustrating.
| DIY phono to replace roksan phono stage | seroxatmad | Analog Line Level | 6 | 14th December 2008 05:46 PM |
| new phono stage or old preamp with phono? | flohmann | Analog Line Level | 2 | 2nd October 2008 09:51 PM |
| PS for phono stage | trianglezerius | Power Supplies | 0 | 20th March 2007 12:14 AM |
| Output stage instability | Katapum | Solid State | 35 | 27th December 2005 04:31 PM |
| Should I replace Scott 222C phono stage with Claret phono stage? | Bing Yang | Analogue Source | 0 | 22nd August 2005 06:41 AM |
| Page generated in 0.06643 seconds (69.45% PHP - 30.55% MySQL) with 10 queries |
