diyAudio Sponsor
Old 25th August 2007, 04:42 PM   #1
matejS is offline matejS  Slovenia
Default Faulty tube?
Hi!
I've a SRPP output stage (preamp) and I've noticed that one channel plays a little but louder. I've checked the circuit components and (soldered) contacts and all where OK.
I found out that in the point where B+ should be halved on one channel it is not. I've changed the tubes (left tube to the right socet and vice versa) and the problem is tube related.
It seems that one half of the tube is not the same as the other. Do I have a faulty tube? Is this a common problem?
Thanks,
Matej
Old 25th August 2007, 04:47 PM   #2
SY's Avatar
In order:
Probably, and it depends on the tube/brand/vintage. What are you using?
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 25th August 2007, 04:49 PM   #3
Originally posted by SY
In order:
Electro Harmonix 6922
Old 25th August 2007, 05:35 PM   #4
anatech is offline anatech  Canada
anatech's Avatar
Hi matejS,
Sounds like a defective tube for sure. Normally they are good, but this one appears to be bad.
Unless ....
If you have no feedback, expect gain differentials. You have to understand that the two tube sections are individuals. They are in no way matched to their mate. There are some circuits that require trimming if no feedback is used. If you expect close gain matching and distortion performance, then you must provide variable circuit elements that allow you to tune your circuit for each tube. This is the same no matter what brand and age of tube you are using.
-Chris
"Just because you can, doesn't mean you should" © my Wife
Old 25th August 2007, 10:13 PM   #5
KaDe is offline KaDe  Germany
KaDe's Avatar
In the classic SRPP stage the tubes need to be matched very careful.
If you have some spare tubes the first step is to select them for half B+ at the test-point, and than check for same gain level.
Some dealers offer SRPP-matched pairs, but they are expensive.
The DIY solution is what Chris recommends.
- can you post your circuit Matej - ?
Old 25th August 2007, 10:16 PM   #6
Yes, no problem. Here it is:
- Matej
Old 25th August 2007, 10:31 PM   #7
KaDe's Avatar
very classic indeed
what you can DIY then is to add adjusters to either R1 or R4 to provide bias correction
Klaus
Old 26th August 2007, 02:26 AM   #8
anatech's Avatar
Hi matejS,
Yes. Clearly you need a way to adjust for gain differences in the first triode.
A commercial example of a circuit with no adjustment is the Counterpoint SA-1000. Takes a while to find tubes matched close enough. The SA-12 / SA-100 amp is another offender with no adjustments for gain matching (VR3 needs to be removed and shorted).
-Chris
Old 30th August 2007, 09:16 PM   #9
richwalters's Avatar
bit late, the ECC88 has a restricted heater # cathode potential with cascade operation.
Perhaps cathode pin 3 is touch faster on warm up than other section.
richj
denom pma250 amp faulty,but no faulty parts found please help homertooties Solid State 1 7th December 2008 03:58 PM
Faulty amp - diagnosis? Omega_Void Solid State 7 11th July 2008 10:52 AM
faulty fostex x-26 Aidan135711 Analogue Source 1 18th March 2008 10:59 PM
Little Dot MKIII, faulty driver tube, GE5654 alternative in the UK? markiemrboo Tubes / Valves 6 6th November 2007 11:34 PM
Is my KEF CS5 crossover faulty? paulot Multi-Way 9 28th November 2001 02:32 AM
Page generated in 0.08850 seconds (82.22% PHP - 17.78% MySQL) with 10 queries
