diyAudio Sponsor
Old 25th August 2007, 02:55 AM   #1
redrabbit's Avatar
Default Philbrick opamp bases
I have a few of these (no tubes installed). Are they able to produce good circuits/sounds?
Philbrick K2-XA
Embree C/50/BP (equivilent to Philbrick K2-W)
http://72.14.253.104/search?q=cache:...ient=firefox-a
Old 25th August 2007, 07:24 PM   #2
bear's Avatar
Probably not too good for audio.
The pinout should be online, or available from the guy on that site you posted. As is the schematic.
However the original tubes are quite premium tubes, fwiw.
_-_-bear
_-_-bear
http://www.bearlabs.com ...live within ~60mi of Albany NY? contact me! --
Old 26th August 2007, 12:29 AM   #3
kevinkr's Avatar
I have a bunch of these, might be useful in a high performance tube power supply as they're basically high performance op-amps. So far I have not figured out how to open them without trashing them totally.
I have K2-W, etc.
Robert Pease (one of my engineering heroes) has written extensively about these vacuum tube op-amps, and you can read about them on the National Semiconductor site here: http://www.national.com/rap/vacuumtubes.html
Particular emphasis is given to K2-W and K2-XA as well some earlier types.
V1 in both is 12AX7A, V2 is 12AX7A in K2-W, and 6BR8A in K2-XA, note the K2-XA also uses a transistor, but without closely studying the schematic I have no idea what it is doing.
www.kta-hifi.net
Old 26th August 2007, 02:53 AM   #4
I'll venture a WAG. Opamps have a differential gain block at their I/Ps. Differential amps work well with constant current sinks in their "tails". My guess is that the transistor is serving as a current sink for the I/P diff. gain block.
Eli D.
Old 26th August 2007, 04:03 AM   #5
redrabbit's Avatar
http://www.philbrickarchive.org/k2-x..._amplifier.htm''
=RR=
Old 26th August 2007, 05:43 AM   #6
anatech is offline anatech  Canada
anatech's Avatar
Hi Kevin, redrabbit,
They would work as a front end for a preamp or amplifier. I know of one tube preamp that uses this concept but not those assemblies (as you would expect). They used a bipolar 150 VDC supply for this arrangement.
So, why not give it a whirl? Mind that the output terminals are high impedance points, also as you would expect. This commercial design used 6922's instead, not surprising from this particular designer.
-Chris
"Just because you can, doesn't mean you should" © my Wife
Old 26th August 2007, 09:27 PM   #7
kevinkr's Avatar
I abandoned global feedback designs about 16yrs ago, and ain't going back.. The K2-W has an open loop gain of 70dB or so - far more than I am comfortable with in most applications.
Actually the transistor in the K2-XA performs a different function, but I have not bothered to figure it out yet.
RAP knows quite a lot about these devices as he worked at Philbrick in the very early days - and his articles are extremely entertaining. I'd read them.
The link I provided in my earlier post provides a lot of information on these devices, and is well worth the time to read..
www.kta-hifi.net
Old 26th August 2007, 10:39 PM   #8
anatech's Avatar
Hi Kevin,
That's fair enough.
No reason not to play with it though. Here you have the sub circuit prebuilt and you could use a short feedback loop.
I have read those articles, many years ago and then a refresher recently.
-Chris
Old 27th August 2007, 01:05 AM   #9
kevinkr's Avatar
Hi Chris,
One area where they might be useful is in a high performance power supply design. IIRC Rap shows such an application for these op-amps in one of his articles. You'd have to wonder though at how good any of those carbon resistors are likely to be at this point.
www.kta-hifi.net
Old 27th August 2007, 02:50 AM   #10
anatech's Avatar
Hi Kevin,
Those resistors are probably not useful anymore. You could rebuild it, but then you may as well simply build it as a new design.
More than one high performance regulator used a tube op amp type circuit.
-Chris
Source for tube bases....? nickds1 Tubes / Valves 0 1st June 2006 09:43 AM
Philbrick metal case op amps nuppe Parts 2 4th December 2004 02:26 PM
WTB B4 and UV4 tube bases bcherry Swap Meet 0 26th September 2003 06:22 AM
Turntable bases diyman Analogue Source 1 29th December 2002 08:04 AM
Very early tube opamp - Philbrick jackinnj Tubes / Valves 0 9th December 2002 01:48 PM
Page generated in 0.12677 seconds (73.05% PHP - 26.95% MySQL) with 10 queries
