diyAudio Sponsor
Old 24th August 2007, 01:56 AM   #1
Mike L. is offline Mike L.  United States
Default Claus Byrith 4-30 Questions
Hello everyone,
I've searched the forums for an answer to my questions. There has been a lot of discussion about the Claus Byrith 4-30 amp design found here http://www.lundahl.se/claus_b.html but no one seems to have addressed my specific concern.
I'm currently laying out my chassis. I've decided to hand wire rather than make the circuit boards. I was first using the "final" schematic presented on page 19 in the first section of the paper. At a later time, I was revisiting possibly making the circuit boards as presented in Appendix IV. When examining the schematic contained in Appendix IV that is used in the circuit boards I found that several new components have been included. Specifically capacitors C3 (220uF) and C4 (220nF) have been added to the feedback loop, and capacitor C2 (47pF) and resistor R4 (4K7) are bypassing the plate load resistor on the EF86. I can find no reference to these additional components in the text of the paper. Could some kind and knowledgeable person explain why these items might have been added?
Thank you.
Mike L.
Old 24th August 2007, 05:20 AM   #2
diyAudio Moderator Emeritus
ray_moth's Avatar
C3 and C4 have not really been added to the feedback loop, they are paralleled to serve as a bypass cap for the cathode bias resistor - something he said he wouldn't do! Evidently he decided that he wanted cathode bypass after all, but forgot to correct the earlier disign details. Some people like to parallel a large cap (220uF) with a smaller cap (220nF) to make a better composite cap, although usually the smaller cap is 1% of the big cap, which would make it 2.2uF not 220nF.
C2 and R4 shouldn't be there, according to the text . Claus reckons he didn't need them once he had converted the EF86 to a triode and dropped its plate load from 100k to 47k (R3). That seems unlikely to me, though, because there's almost certainly going to be a peak in the high frequency gain with the global NFB loop, and you need that little Zobel network to correct it. Maybe Claus discovered this and changed his mind later, but forgot to correct the earlier disign details.
Old 24th August 2007, 01:11 PM   #3
Thanks very much for the explaination. I guess I'll go the hand wire route. That way it will be easier to add/remove these questionable components and listen for sonic differences.
Claus Byrith 30W PP kmj Tubes / Valves 169 11th June 2010 12:20 PM
Help on PP EL 34 from Claus Byrith Maurizio Tubes / Valves 7 7th November 2009 05:28 PM
Some Quad els57 questions! - Novice Questions! Fanuc Planars & Exotics 13 5th December 2007 09:26 AM
Eico HF-20 & Claus Byrith PS voltage & power draw Valvomaniac Tubes / Valves 0 27th March 2007 07:53 AM
Using the Crowhurst articles and Claus Byrith eddog Tubes / Valves 8 16th February 2006 08:11 PM
Page generated in 0.07423 seconds (72.66% PHP - 27.34% MySQL) with 10 queries
