Old 22nd August 2007, 11:35 PM   #1
anli is offline anli  Russian Federation
Default triode thermodynamic model
Does such model exist? I mean a changing of triode parameters as function(s) of currently dissipating power. In SS world such dependence is known as "memory distortions".
Old 23rd August 2007, 04:54 PM   #2
kevinkr's Avatar
Interesting question, I don't believe there is any exactly similar mechanism in vacuum tubes, however there are small parameter shifts that occur during warm up as internal electrode dimensions change.
This is well outside of my area of expertise. I would refer to Terman, RDH4 or one of the other old textbooks to determine whether there are any similar mechanisms present in standard or purpose designed tubes. (I'm not aware of anything similar to memory effect in transistors in the tube world. Thermal tails, etc.)
Note that like transistors and jfets tubes do exhibit some shift in dynamic transconductance as a function of the instantaneous current flowing through them.
"Extraordinary claims require extraordinary evidence." - Carl Sagan
Old 23rd August 2007, 05:15 PM   #3
Originally posted by kevinkr Note that like transistors and jfets tubes do exhibit some shift in dynamic transconductance as a function of the instantaneous current flowing through them.
OK, anything depends on anything Here I'm interesting in thermo-modulation, and the main difference I can see (with respect to SS) are much longer time constants which describe power dissipation influence to a transconductance (you see, such thermal inertia model may be described with help of LPF with certain time constants, as at SS case). I think, at such situation "SS memory distortions" become "additional pseudo-reverberations", and last ones are one of the reasons tube audio-chains sound more "live" and "musical".
Old 23rd August 2007, 06:05 PM   #4
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
I don't see there being a signal-dependent thermal effect in valves. Consider the size of the active bit of silicon inside a transistor, now consider the size of a valve electrode structure with similar ratings/usage. The thermal mass of the valve is much higher and any signal-induced heating is likely to be swamped by the nearby heater.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 23rd August 2007, 06:32 PM   #5
The thermal modulation definitely exists (I know such measurements were accomplished). To estimate time constants we need qood square wave oscillator (with frequency, say, 0.1-0.2Hz) and ADC working from 0 Hz (i.e. with DC-open input) - probably good digital scope with recording will be suitable here. I have not such equipment.
I don't say about any influence at *sound* frequencies. I say about infra-low frequencies and about modulation of *sound enveloping*. And such modulation is, I think, similar to reverberation, if we say about our ears and something between them
Old 23rd August 2007, 07:11 PM   #6
JohnAtwood's Avatar
Default Thermal model
There is probably more of an effect from anomalous behavior of the cathode rather than pure thermal effects. The oxide-cathode is a complex system that was only barely understood during the heyday of tubes. Look for references on the "cathode interface" problem for more on this. A good place to start is RCA's in-house publication "Electron Tubes". It can be found at: http://frank.pocnet.net/other/RCA/RC...be_Design.pdf. (Warning: 88Mbytes!)
- John Atwood
Old 23rd August 2007, 07:41 PM   #7
Default Re: Thermal model
Originally posted by JohnAtwood There is probably more of an effect from anomalous behavior of the cathode rather than pure thermal effects. The oxide-cathode is a complex system that was only barely understood during the heyday of tubes. Look for references on the "cathode interface" problem for more on this. A good place to start is RCA's in-house publication "Electron Tubes". It can be found at: http://frank.pocnet.net/other/RCA/RC...be_Design.pdf.
Thanks, I'll look for. At any case it is interesting to look at square-waves testing. Slow sound changings (say, with characteristic time interval about one second) are very sensible for our ears, and thermal modulation in "heavy" parts may be inside this frequencies range - say, 0.1-10Hz).
Originally posted by JohnAtwood Warning: 88Mbytes!
Ups.. It's rather costly for me
Old 24th August 2007, 12:35 AM   #8
d2134 is offline d2134  Romania
Send a message via Yahoo to d2134
Here is a link. It may help you.
http://audioportal.spb.ru/plugins/p2...2_articleid=18
"Importantly also that that the basic parameters of lamp do not depend on the temperature of the anode or, otherwise, from the power being dissipated on it."
(This quote was traslated by babelfish)
Old 24th August 2007, 01:14 AM   #9
At the same site there is a forum thread with opposite information. But nobody has published recorded square signal. To be more strictly, I don't know such publications. And this thread aim is to get such concrete info or to inspire tektronix owners to accomplish such measurements. Is there anybody brave?
Improvement to DM's Generic Triode Model for 12AU7 Joel Tubes / Valves 3 13th August 2009 03:43 AM
4E27 Triode connection SPICE model ja2dhc Tubes / Valves 3 6th June 2009 12:30 AM
Another 3f4 spice triode model: 5718 submini triode wa2ise Tubes / Valves 0 5th September 2008 04:31 AM
PP-Triode , PP-UL , PP-Pentode-strapped-as-Triode percy Tubes / Valves 23 22nd January 2007 12:36 AM
ts9 pt9 triode desperateaudio Tubes / Valves 0 8th February 2006 06:58 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
