| diyAudio Sponsor | ||
Hello to everyone, I am a new member here and I was advised by another member to start a build thread and watch the advice and tips come flowing my way.
In the way of background, I am new to DIY, having only built a cheap CMOY headphone amp and a SOHA tube hybrid headphone amp based on the writeup at www.mb3k.com. I am currently a 4th year undergraduate studying physics, so I have some background but nothing compared to the level of knowledge of everyone here. My current setup is as follows: Sources: Yamaha YP-B4 Turntable Rega Planet CDP Apple Airtunes Preamp: NAD 7000 Moniter Amps: SOHA B&K ST-140 Speakers: Wharfedale Diamond 9.2 Sennheiser HD580 I am thinking of upgrading my TT, and also now wanting very badly to build a preamp with some tubes in it (after my WOW! experience with the SOHA). I know my system is nothing to drool over, but it is very adequate for my listening enjoyment. Onto the quest: I want to build a 12B4. Since I am a college student without a steady income, I need to keep the costs down, which I was assured was possible in another thread I started.I have read through a lot of a thread started by Mark A. Gulbrandsen called "Yet another 12B4 line stage, or is the 12B4 better than the Grounded Grid." After my reading I emerged more confused. I am uncertain about a couple of things to start with, namely the favored schematic. I read that Brian Beck's is a definite upgrade over the original, but that there were some electrolytic caps that needed to be bypassed by decent filmcaps for a preamp application. Along with the schematic comes the need for a PS schematic. Since I am new at all this, I am not really sure how to make a schematic out of all the instructions people give, so I am wondering if there are schematics out there for what I am looking for. One option for PS that I am considering is this one: http://www.glass-ware.com/tubecircui...egulator.html. It seems that the parts required are inexpensive and it is relatively easy to construct. I am somewhat confused about where I would connect a transformer to the regulator, and also what sort of transformer I would need for this. Since this is a build thread, I will update irregularly as I work on this or as questions arise, including posting BOM's for approval and pictures as necessary. I appreciate any and all advice and look forward to working on this line stage! Best, Colin |
#2 |
Hi, I would suggest you use 2 x VR150 voltage regulator tubes to give you 300V. I'm not sure how expensive those are in your area, but they're cheap here where I am. They also give you a nice purple glow, and that's a conversation piece. This is very simple to implement compared to that circuit you posted.
I'd use SS rectifiers and a couple of 450V (CRCRC) capacitors before the VR150, to keep costs down. I can make you a schematic for this. We will need to know how you'd be operating you 12B4, so that we can determine the current requirements for the PSU. If you're leaning towards Brian's LM317 CCS cathode configuration, you can use decent Illinois film capacitors to bypass the electrolytic. Illinois caps are not that expensive. ps. Here's the Illinois Cap MPW series (Polypropylene) ![]() Illinois Capacitor give samples, so this will come in handy. |
#4 |
I am not sure exactly what you mean by how I will be operating the unit, but I will give it a shot. I basically want to replace my NAD 7000 with the 12B4 unit. I want to have at least 4 or 5 inputs, and at least two outputs. I will need to send the pre to the power amp and be able to control the volume just like my NAD. I am hoping to build a phono stage after building this project successfully to incorporate my turntable into the setup. I am not sure exactly what you mean by this, so if I didn't properly answer the question let me know and I will clarify as best as I can. Also, when you say bypass the electrolytics does that mean to just altogether leave them out and use a film cap in their place? What is the purpose of this? Best, Colin |
#6 |
planet10,
Thanks for the schematic (the first one). It raises a couple of questions for me: 1. There is one unlabeled resistor and one unlabeled capacitor, what the required values for these components? 2. I assume I am getting ahead of myself here, but what is the pin configuration of the 12B4? How does that correspond to this diagram? 3. I am assuming that the open/closed circles on the right and left upper corners are refering to inputs/outputs, if so, which is which? Thanks! Colin |
#7 |
The second is very much clearer to me, but I still have a couple of questions now. A previous poster mentioned using two VR150s to acheive 300V while giving a cool purple glow effect (which is very appealing to me
#8 |
Oooh I am on a role here, Brian's schematic just shows one channel, correct?
#9 |
Hi Colin,
Have a look a this PSU for Brett's design |
#10 |
I also annotated the schema of Brett for the other stuff you're asking for...
| Yet another 12B4 line stage, or is the 12B4 better than the Grounded Grid..... | Mark A. Gulbrandsen | Tubes / Valves | 789 | 8th March 2011 12:04 AM |
| Phono stage for 12B4 amp [from previous thread] | coffeedj | Tubes / Valves | 1 | 2nd April 2009 09:26 PM |
| 12B4 Battery Bias from (Preamp: Foreplay or 5687 or 12B4 ) | DougL | Tubes / Valves | 3 | 2nd August 2004 06:06 PM |
| Page generated in 0.13910 seconds (77.82% PHP - 22.18% MySQL) with 11 queries |
