smoke came from transformer
Old 21st August 2007, 06:06 AM   #1
filipolaz is offline filipolaz  Hong Kong
Default smoke came from transformer
I have a Counterpoint 5.1 tube pre-amp, after I found the 2A fuse is broken then I put a 3A fuse to replace.
When I powered on, I saw smoke came from the power supply and smell the smoke is coming from the transformer.
Is there any suggestion, I need your help !
Thousands thanks in advance.
Old 21st August 2007, 06:09 AM   #2
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Default Re: smoke came from transformer
Time for a new transformer, The 2A probably blew because it was on its way to failing already, The 3A (and the smoke) just confirmed things.
Pretty stinky wasn't it?
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 21st August 2007, 06:13 AM   #3
dsavitsk is offline dsavitsk  United States
dsavitsk's Avatar
Suggestion 1: Don't overrate fuses. They are there for a reason.
Suggestion 2: Find, and fix, the problem in the amp that blew the fuse in the first place before trying to power it up again.
Suggestion 3: Remove the power transformer and check it for shorts, etc. If it seems okay, power it up on its own (with a proper fuse) to see if it works. If it does and you have fixed the problem in the amp, reassemble it and test (with the proper fuse.)
Old 21st August 2007, 06:25 AM   #4
frugal-phile(tm)
planet10's Avatar
Default Re: Re: smoke came from transformer
Smoke coming out of the transformer is a VERY good sign that it has a short.
dave
Old 21st August 2007, 06:31 AM   #5
poynton is offline poynton  United Kingdom
poynton's Avatar
Suggestion 4: Keep the lid on and don't let the smoke out. Everyone knows old amps are powered by smoke!! If that fails , replace the transformer and check the rectifier and caps.
Andy
Old 21st August 2007, 10:37 AM   #6
Burnedfingers is offline Burnedfingers  United States
Put in or a smaller value fuse back in until the problem has been found.
Use a variac to power it up or a light bulb in series with the power cord. Sometimes one needs to power it up to find the problem.
Old 23rd August 2007, 08:16 AM   #7
Thank you very much for the suggested solutions. All suggestions are taken into account and will be carry out step by step.
smoke came from transformerHide this!Advertise here!
Zen V4 smoke.... rebojorge Pass Labs 8 20th December 2007 08:34 PM
T-amp up in smoke jwb009 Class D 21 4th April 2006 06:50 AM
I let the smoke out. TerryG Class D 16 8th November 2005 06:25 PM
trio amp up in smoke-ya really up karma Tubes / Valves 11 5th July 2004 10:28 AM
Up in smoke... PhaseShift Solid State 2 3rd September 2002 05:03 PM
Copyright ©1999-2017 diyAudio
