diyAudio Sponsor
Old 21st August 2007, 03:44 AM   #1
Cycline3's Avatar
Default Old or new output transformer?
OK, here's my problem. I have a pair of output transformers from an EICO HF87. Many of you know -- they are excellent quality. I built a tube amp around them back in the 80s and the power transformer (50s era) has failed. I want to build a new dual mono amp for my main stereo... and my problem is... do I use the excellent, yet getting very old transformers OR risk going with a new hammond/edcor/whatever? I have a hard time thinking I'll get a better output transformer than what I have, but in putting in all the hours of work into a new amp, I'd like to think it is going to be fairly reliable. Any thoughts? My gut is telling me to use the old ones, my common sense is telling me to use new... alas...
Old 21st August 2007, 04:19 AM   #2
Send a message via AIM to DigitalJunkie
As long as the wiring,etc. on the old ones isn't brittle and falling apart... I'd go ahead and use them.
They shouldn't fail,unless the bias fails,or some other 'catastrophic' event,-which could damage a new tranny (and/or tubes) just as easily as an older one.
my .02 anyways..
Old 21st August 2007, 05:58 AM   #3
frugal-phile(tm)
planet10's Avatar
Go ahead use the old ones... even with new ones it is a good idea to do the build so that different transformers can be swapped in.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 21st August 2007, 01:13 PM   #4
SY's Avatar
I'll be the contrarian. The Eico opts (made by Chicago Transformer) are pretty good, but they have their problems. The severest one is a fairly substantial side-to-side imbalance at high frequencies (note the 1nF cap in the original circuit to try to fix this). On the bass end, the Eico transformers are very good, and much better than competitive Dyna or Acro units.
But if I were taking the trouble to scratch-build an amp, I'd go new, both for reliability and performance. With modern opts, you get new and better insulation, new and better core material, and new and better winding techniques. I would guess that $200 would get you a pair of new opts that would blow away the Chicago iron.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 21st August 2007, 03:06 PM   #5
arnoldc is offline arnoldc  Philippines
Send a message via Yahoo to arnoldc
Like James
Old 21st August 2007, 05:12 PM   #6
Cycline3's Avatar
OK.. a little more info:
I don't use the EICO circuit at all. So referring to the original amp in ref to the transformers may not apply. The transformers are physically in excellent condition - the wiring and insulation is in some of the best condition I've seen on vintage parts. So in that case, they are good to go. As for sound - I won't write them off as easy to best, they are excellent and I've got a lot of WOWs from friends and audiophiles (with lots of experience with gear) alike. Plus, they impress me and I count the most! So it does in some extent boil down to - I am not sure I'll get better iron from new parts but I want this thing to last another 20 years. I suppose I could breadboard and test old iron vs new for sound quality before I build the final amp... and I suppose I'll have to consider it. I do appreciate everyones comments and hope we get some more opinions on here to help me decide. Thanks everyone.
Old 21st August 2007, 05:43 PM   #7
frugal-phile(tm)
planet10's Avatar
I'd still go ahead and use the old iron. You should always design to accomodate the option of replacing the iron later -- even if it is brand new iron.
It also depends on how much you total build is going to cost.
dave
Old 21st August 2007, 06:15 PM   #8
richwalters's Avatar
Bit awkward this one...... if the transformers were manufactured to class A then alone materials enamel etc are expected to last 20 years continuous slog. If overheating and stress as taken place then times up ! Judge for yourself.. ??
However the catch as Planet 10 mentions always recon for Murphies Law. Modern-day replacements from good vendors can out perform old ones and put budget aside.
Another 20 yrs from now will see only a few types of popular tubes about.
richj
Old 21st August 2007, 06:29 PM   #9
HollowState's Avatar
I agree with the others, use the old transformers since you like them and say they aren't dried out. To help assure their safety, consider putting an appropriate sized slo-blo fuse in the B+ feeding the center to protect them from a catastrophic tube failure.
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University
Old 21st August 2007, 07:36 PM   #10
anatech is offline anatech  Canada
anatech's Avatar
Hi SY,
Well, you know I have an Eico HF-87 that usually sounds great. What transformers would you consider using as replacements?
Oddly, I found the very high frequencies the best on these. Very clean.
-Chris
"Just because you can, doesn't mean you should" © my Wife
Difference between SE output transformer and push-pull output transformers hilbert_mostert Tubes / Valves 12 8th March 2009 05:10 PM
3C24 in a SE output stage - output transformer impedance recommendation !!! aldovan Tubes / Valves 15 6th September 2008 10:18 AM
Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 freddymac406 Tubes / Valves 3 21st April 2007 06:15 PM
Can An Output Transformer Change A Voltage Amp's Output Impedance From 0.1 To 47 Ohms kelticwizard Everything Else 11 25th March 2007 05:17 AM
toroid Transformer as output Transformer for tube preamp? tone Tubes / Valves 15 2nd February 2003 04:36 AM
Page generated in 0.11772 seconds (75.52% PHP - 24.48% MySQL) with 10 queries
