| diyAudio Sponsor | ||
http://www.edn.com/article/CA302240.html
Anyone tried this? Looks interesting, but you you would need more iron on the amplifier
#2 |
Here's some more boosted triode results. No need for more iron and done heretical http://geek.scorpiorising.ca/GeeK_Zo...18638#msg18638 Cheers! |
#3 |
When I first saw the article in EDN I was skeptical, so I tried it. The result? A fried 6L6GC. The author of the article "built" the circuit in a simulator. The simulator may not "see" the glowing screen grid. See post # 18 in this thread:
Triode Trick And: 6L6 Design in EDN Mag And: Tube article in EDN I believe that Geeks "boosted triode" is a different design, similar to what I called "dual drive" where the screen and control grids are both driven (at different DC potentials). It works, but the results are dependent on the type of output tube.
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
| Using a spdt switch to select between triode mode and pentode mode on a guitar amp. | G | Tubes / Valves | 19 | 15th March 2006 09:15 AM |
| 6V6 in triode connect mode | cominup | Tubes / Valves | 13 | 2nd May 2005 05:35 PM |
| EF86 Triode Mode | Family_Dog | Tubes / Valves | 4 | 21st March 2005 04:41 PM |
| Mullard 5-20 in triode mode | icebear | Tubes / Valves | 15 | 26th November 2004 02:06 AM |
| Page generated in 0.06751 seconds (68.03% PHP - 31.97% MySQL) with 10 queries |
