| diyAudio Sponsor | ||
Hi all,
I have picked up two second hand potted 240V / 120V transformers. Will it be ok to parallel primary's and series the secondary's to give me 240v AC B+ Supply Voltage? Any major issues with using the two on top of my pre-amp chassis? I have not had a lot of luck finding a suitable single tranny in Oz (reasonably priced that is). Cheers Dave |
#2 |
#3 |
You can also use a simple 1:1 isolating transformer. Usually these are not too hard to come by and quite cheap.
Moskido (Hybrid Aikido/Mosfet); Verumecce (biased interconnects). Buffalo III with Unbalancer tube output; Magnepan 3.6R |
#4 |
Beau,
He already has the transformers. I interpreted his question as asking if he could get the voltage he needs out of the transformer(s) he has. Transformers are expensive. Aloha, Poinz |
#5 |
Hi Poindexter,
Thanks for the reply. I was not aware I could get double the voltage in this way. I will have a look at it in PSUD. Would your circuit as shown provide an adequate Filter for the Akido ? Another option I thought of was to wire it up in reverse, so I get 480VAC and filter down with LC's until I get desired 300VDC? I have plenty of Caps but would have to source the chokes. Cheers Dave |
#6 |
Hi again
After reading another thread, I could piggy back the two TX's - 240 - 120 - 120 - 240. Are there any advantages to this? Would this filter some noise from mains? Cheers Dave |
#7 |
#8 |
Thanks for the replies Poinz.
If there is nothing to be gained by using the two Tx's and a full Bridge rectifier, I will use one Tx and a voltage doubler. Thanks for the schematic, I will put it into PSUD and have a look. Cheers Dave |
#9 |
You won't be able to plug the voltage doubler into PSUD, as it has no provision for anything but the standard connections. But you can probably come close by using entering twice the measured voltage and resistance of the secondary, and half of the combined capacitance of your series C. Everything after the first C is done the normal way.
Sheldon |
#10 |
PSUD has the full-wave voltage doubler in its library of rectifier circuits; I use it all the time.
Aloha, Poinz |
| Power Supply for Aikido Phono Pre | Binaural | Tubes / Valves | 16 | 9th November 2008 07:45 PM |
| Need help with Aikido power supply | JayH3 | Power Supplies | 3 | 22nd June 2008 02:48 PM |
| General Aikido power supply question | eddog | Tubes / Valves | 6 | 24th November 2007 12:50 AM |
| Aikido Power Supply | dr._sleep | Tubes / Valves | 13 | 27th August 2005 04:57 PM |
| Page generated in 0.10296 seconds (70.30% PHP - 29.70% MySQL) with 10 queries |
