| diyAudio Sponsor | ||
Hi:
Here's the circuit I have for an 845 based amp. I'd like to hear what critiques or suggestions anyone may have of it. Thanks -- Minto |
#2 |
Well Minto, I think I'll be the first of many to say that your circuit is not a good one for several reasons. I'll just touch on the obvious weak points.
845's are difficult to drive. They can draw grid current that must be supplied from a good low inpedance drive source. You'll need a high current cathode follower or mosfet source follower like tubelab's to directly drive the grid. (no coupling cap) And the 100K ohm grid resistor is too high in value. This tube also needs a high amplitude signal to provide any usable power out. I doubt your 12AU7 is going to provide that signal. DC on the 845 filament is ok (even good), but what is doing with that CRC business with an 8200 (?) ohm resistor? I assume that 5Z3 is for a slow B+ arrival. I think I'd rather see a delayed relay across a dropping resistor of a suitable value. This is more or less designer's choice. I also think you'll need some overall NFB. I see some other minor questionable things futher back, but I think I'll stop here. Victor edit for syntax
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University |
#3 |
Agreed on the 12AU7 being too small to push grid current. At the very least I would say a 12B4/6CG7 or a triode strapped pentode like a 6AU5 or 6W6. The 5998 seems ideal for driving an 845 but I dislike the idea of having both channels going into the same tube. My current 845 amp uses a 417A driving a 6AH4 triode. The bottom line is the driver tube must draw a good amount of current, say at least 15mA.
#4 |
Here are a couple that I had on file. I also have some with interstage tranies as well if you want.
Cheers George |
#5 |
and
#6 |
#7 |
Thanks very much for all of your input and the schemaic. This circuit is for the Audioromy 845 stereo integrated amp. I just bought one on Ebay for $320. I look at it as a cheap investment into some parts. I can't afford the good stuff so this will have to suffice.
I am also considering Pete Millett's 12hg7 fron end that he used on his 813 amp. The schematic from Yves is very similar and looks to be be a good one to experiment with. The amp wont be here for at least a month so I am only in the preparatory stages. Once again thanks and I wish you all well. Ciao -- Minto |
#8 |
Oh yes, George and Yves:
Thanks very much for the schematics. I will have to stick with resistive loads as chokes are added expense. I will go to work today and print out the cicuits you have given me and study them. Thanks very much -- Minto |
#10 |
845's like interstage transformers.
What does the VL208 choke and the two resistors and capacitors before the 6GB8 grid do? Looks to me like a low pass filter? |
| Circuit board repair suggestions? | NewVintageNut | Solid State | 7 | 7th January 2008 07:21 AM |
| Suggestions on Balanced Bridge circuit | Mambo | Solid State | 5 | 12th January 2007 04:05 PM |
| Trouble with speaker protection circuit (Randy Slone's circuit) | whalefat | Solid State | 3 | 13th April 2005 10:13 AM |
| Sony SACD clock circuit - suggestions? | dorkus | Digital Source | 29 | 26th December 2002 10:04 PM |
| Page generated in 0.12294 seconds (70.40% PHP - 29.60% MySQL) with 11 queries |
