Finished a BottledHead Foreplay preamp and used all the standard kit parts for the inside ,(not outside). It sounds ok, as I think the tubes that came with it are not top notch. I have ordered some mullard 12au7's to try out. I imagine there is some break in period, but I do not know much about that. |
#2 |
Very nice matching set..
I have read that the Foreplay needs a certain amount of break in time.. I wouldn't think that it would be that long.... You might want to ask that on the Bottlehead fourm..ck |
#3 |
GORGEOUS!
I hope that it does burn in to your liking. And like you say, maybe a different set of tubes. |
#4 |
Man , do they look good!
- Jan - |
#5 |
That's a cool looking diy pre-amp!
Jonathan Blanchard (J.Bl.) ---Nothing is impossible--- |
#6 |
ABSOLUTELY, 100% POSITIVELY GORGEOUS!
wow. im impressed. i love the copper and dark wood approach. looks killer! |
#7 | |
what are you comparing it to? You are running it with your JElabs 300bs if I remember right? Cheers Craig Ryder
Ryder Any fool can ask more questions than seven sages can answer. |
#8 |
OH-MY-GOD!
I want one so bad... |
#9 | |
I did have the CDP hooked directly to the JE amps and after adding the preamp, the music seemed to loose some detail and focus. It is sounding a little better right now and I hope it will age well. |
#10 |
diyAudio Senior Member
Hi Paul,
First of all congrats on another marvelous piece of art....you have once again created one of those DIY jobs that don't look at all DIY. Adding another stage into the chain is likely to have a detrimental effect on the sound,no matter how good it is.... Have you looked at phase inversal by the preamp? That may well be the culpritt of what you observe. Cheers,
Frank |
| Foreplay Preamp volume popping | arc2v | Tubes / Valves | 7 | 22nd August 2007 03:04 AM |
| My ForePlay Processor Controlled Preamp | Algar_emi | Tubes / Valves | 34 | 14th December 2005 05:38 PM |
| Preamp: Foreplay or 5687 or 12B4 | Toyman_PA | Tubes / Valves | 24 | 4th August 2004 04:10 PM |
| 12B4 Battery Bias from (Preamp: Foreplay or 5687 or 12B4 ) | DougL | Tubes / Valves | 3 | 2nd August 2004 06:06 PM |
| Tube preamp similar to Foreplay | JAZZ2250 | Tubes / Valves | 6 | 10th December 2002 10:14 PM |
