#11 |
frugal-phile(tm)
Paul,
Did you add the optional CCS to your Foreplay? I understand this makes a huge difference -- as it does on most CF stages. dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#12 | |
diyAudio Senior Member
Ciao,
Frank |
#13 | ||
To all who have responded, Thank you!
This did cross my mind, adding more resitors, caps, ect to the signal. Quote:
Not yet, I do have this 'upgrade' , but did not install it yet. I want to listen to the preamp for a while, then add this. To see if I can hear a difference. By the way, my next project is speakers, DIY of course. Would you have any recommendations for me to look at? |
#14 | |
Hi Paul,
If you allow me.... Quote:
As for speakers,well that is of course Daves' department...I'd be looking at a FR 94dB+ or similar arrangement. Happy building,
Frank |
#15 | |
frugal-phile(tm)
There are many potential speaker projects... what kinds of things have you had your eye one? I'll ask some more questions as we go along (and probably split this off to the Loudspeaker forum once we have a couple posts happenin') dave
#16 |
Hi Paul
Lovely job on the pre-amp, and the amps. Your earlier thread on the power amp construction inspired me to start chassis building, but that's another story. I have played a little with different 12au7, although in my case they are drivers for 300B not preamp. I found that the late production Mullard (70s & 80s) were a bit ordinary, although perfectly good. Early Mullards are better, but the best I have tried were Amperex Bugle Boys. |
#17 |
RIP
The changes that the C4S's bring to the Foreplay are not subtle. Some, who get used to the rather lush character of the stock unit have a hard time getting used to the changes - but most are running it into SS amps.
Paul Joppa calculated the operating points for a number of different tubes with that circuit at the following post... http://www.AudioAsylum.com/forums/bo...ges/21342.html You'll need a beefier tranny for most(or a separate filament tranny). Auricaps for the output caps also offer alotta bang for the buck. |
| Foreplay Preamp volume popping | arc2v | Tubes / Valves | 7 | 22nd August 2007 03:04 AM |
| My ForePlay Processor Controlled Preamp | Algar_emi | Tubes / Valves | 34 | 14th December 2005 05:38 PM |
| Preamp: Foreplay or 5687 or 12B4 | Toyman_PA | Tubes / Valves | 24 | 4th August 2004 04:10 PM |
| 12B4 Battery Bias from (Preamp: Foreplay or 5687 or 12B4 ) | DougL | Tubes / Valves | 3 | 2nd August 2004 06:06 PM |
| Tube preamp similar to Foreplay | JAZZ2250 | Tubes / Valves | 6 | 10th December 2002 10:14 PM |
