diyAudio Sponsor
Old 16th August 2007, 03:16 PM   #1
arc2v is offline arc2v  United States
Default Foreplay Preamp volume popping
I have a Bottlehead preamp feeding two ASL wave8 amps and then going to Adire HE10.1 speakers.
Everything was working fine up until last week when I noticed something.
Every time I adjusted the left volume knob, or even pushed it a bit without turning it I got a DC pop in the left speaker. The woofer jumped about half an inch and I shudder to think what might have happened to the tweeter (so far everything sounds okay).
The volume knobs are separate on the channels and the right one does not exhibit this behavior.
The knobs are stepped switches with different resistor values wired in at each junction (i.e. not a potentiometer). Bottlehead referred to this as their Sweet Whispers upgrade.
Any idea what might be causing this? No solder joints look broken and nothing else has changed (tubes, source, etc).
Thanks,
AC
Old 16th August 2007, 03:32 PM   #2
Default popping
Hi ARC,
Could be several things, such as the switch having contact problems or a cold solder connection, even though the connections look ok.
If the contacts lose connection for just an instant, the grid may 'float', causing a thump. Is the switch a high quality one, or a basic open type kind that could get dirty?
Is it possible that something inside could be slightly moved when 'working' the switch, indicating a loose connection at another location?
Hope this helps.
Positron
Old 16th August 2007, 04:24 PM   #3
Thanks for the help.
It's a high quality "open" design. Very firm contact (basically a ball bearing between two plates with detents). I have some contact cleaner, so I'll hit the switch with it tonight.
I'll also check for cold solder joints.
Worst case, I can always go back to the pots, but this really did improve the sound quality when I installed it.
Thanks again. I'll report back tomorrow.
A
Old 16th August 2007, 04:43 PM   #4
VoltSecond addressed this in his website, which is here: http://www.siteswithstyle.com/VoltSecond/index.html
You might also try this: http://www.audioasylum.com/forums/bo...es/105505.html
Old 16th August 2007, 04:54 PM   #5
Thanks. I had been spending a lot more time here than over at the Asylum recently, which is why I posted here.
I searched over there and found a variety of problems, most stemming from the break-before-make problem.
I'll look into a large value shunt resistor on the wiper or just cleaning the contacts thoroughly.
I also need to lower the volume substantially. Right now the lowest detent above mute is putting out about 80dB, which is fine for normal listening, but a bit loud late at night, or distracting if I'm trying to read. Ideally that volume should be at the 2 or 3 position, giving me enough room for "background noise" levels. So I'm gonna be soldering away anyhow, so might as well try the Voltsecond trick.
Thanks again. I'll post results once I try a few of these out. I never want to see that woofer jump like that again. Ouch.
Old 16th August 2007, 05:02 PM   #6
I "upgraded" to the 100K Alps pots that Radio Shack (used to?) sells for $2.99. I got two to preserve the left-rightness (I am one of those whacko's who likes that feature).
I found them a considerable improvement over the originals.
Old 16th August 2007, 09:18 PM   #7
Default popping
Yes, a break before make is definitely not a good idea. Installing a high ohmage resistor from wiper to gnd may still cause some popping.
The best solution is either a make before make rotary, or continuously variable volume control, if this is causing a problem.
Another possible cause is a tube. Might tube roll just to be sure, before spending on new parts.
Just a thought.
Old 22nd August 2007, 03:04 AM   #8
Fixed it without firing up the soldering iron.
The rotary switch had worked itself loose. While I had the lid off, I tighened them down and noticed it made the knob harder to turn. So on a hunch I figured the connection would be better too.
Fired it up and the pop is gone. Who would have though it would be that simple?
Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps MartyM Tubes / Valves 3 16th October 2008 04:52 AM
My ForePlay Processor Controlled Preamp Algar_emi Tubes / Valves 34 14th December 2005 05:38 PM
Preamp: Foreplay or 5687 or 12B4 Toyman_PA Tubes / Valves 24 4th August 2004 04:10 PM
Pics of Foreplay Preamp TubeHound Tubes / Valves 16 5th February 2003 01:29 PM
Tube preamp similar to Foreplay JAZZ2250 Tubes / Valves 6 10th December 2002 10:14 PM
Page generated in 0.09526 seconds (86.35% PHP - 13.65% MySQL) with 10 queries
