| diyAudio Sponsor | ||
Hi all,
I'm interested in building the 26 preamp found on VT52.com but am not sure about some things. The simplicity of the circuit both attracts me and scares me. ![]() http://www.vt52.com/diy/myprojects/amps/26bat/26bat.htm 1. There is no value stated on the input pot, so I will be using a 100K stepped attenuator i have lying around. Is this fine? 2. There are 2 preamp stages running parallel to each other. I am only interested in the 26 bit and the comments on the webby says that the 2C51 bit is to be used for LF work, so will I still get full range sound if I just remove the 2C51 bit and just build the 26 bit? 3. I have a 330-0-330 80mA tranformer lying around (leftover from previous projects) and would like to know if it will be able to meet the power requirements of this project. I'll only be building the 26 bit. I'm quite sure it would, but seeing that vt52.com used a 100mA spec-ed tranny for EACH channel makes me feel small. I'll be modelling in PSUD to adjust for the right B+.4. The schematic lists the current draw for each part of the preamp to be 8mA (so total current draw = 16mA?), so I presume I can use just one of my 330-0-330 80mA transformer to power 2 channels? My 5V transformer will be separate (my current tranny only has 6.3-CT-0 windings ) and I'll probably go for GZ34, 5Y3 or 5U4. Maybe I'll try my luck with some mercury vapour 83. 5. Would the 1:1 line stage transformer do the job properly? Having seen some other with output transformer preamps with different winding ratios makes me feel uneasy. Tranformers aren't cheap. ![]() I'm hoping the simplicity of this project will let me use high end components without burning too big a hole in me pocket... and contribute towards the transformer cost. edit: On another note, how do you guys think a RF remote control would do for this preamp? Would it interfere with the audio signal? Probably getting some generic TX/RX RF modules operating in the range of around 300-400MHz to control power, volume and input selection. IR requires me raising the remote and isn't really much simpler than RF to build, though part sourcing is much easier and costs lower. Thank you for reading. |
#2 | |||||||
http://www.ecpaudio.com |
#3 |
I would suggest that if you haven't built many projects to leave the 26 alone because its a humming bast**d. Check out kevinKr because he has made a very nice 26 that is very workable.
dsavitsk suggested not using the 83 and he is 100 correct on that. |
#4 | |
cheers 316a |
#5 |
Try Kevin's version of the 26 preamp.
#6 | |||
Thanks! |
#7 |
Hi, Kevin's pre *is* fixed biased.
#8 | |
http://www.kta-hifi.net/projects/pre...26dhtpre-1.pdf http://www.positive-feedback.com/Issue16/kennedy.htm Isn't R1/R4 for biasing? |
#9 | |
I think you are confusing fixed bias with cathode bias. This is a fixed bias design and all that really means is that the bias voltage is fixed externally and not generated by the current flow through the tube itself. This has the significant benefit of allowing you to easily tune operating point to the transformers, tubes and supply voltage you are using. You can't remove the coupling capacitor on the grid in this design because it sits at about -9V relative to ground. You can use a 9V battery to supply your bias. (You can omit the pots and associated circuitry in such a case, just connect the - end of the battery to the grid resistor, + end to gnd.) Cathode bias requires a large cathode bypass capacitor and separate filament supplies for each channel. Good cathode bypass caps (they are very audible in this sort of application) are quite costly and take up a lot of space. A good film cap in the high impedance grid circuit will handily outperform a not so mediocre cathode bypass cap. Your supply transformer is barely workable, the problem is that you have to drop about 250V prior to the 26 plate to line transformer. The ideal operating point for the 26 is around 6mA and 150V (or somewhat less) This transformer would be ideal for use with the regulator circuit however. You can use unregulated plate and bias voltages, and although the design does look complex it is actually pretty simple to get working. Very quiet supplies are a must, and the filament supply must be ripple free dc. Magnetic and electrostatic coupling to the 26 is a big issue, shields around the tubes are a must. I recommend a separate chassis for the power supply to keep magnetic fields away from the plate to line transformers. It is very difficult to eliminate all coupling, but an over size chassis can help in the case where a single chassis is desired. Use aluminum to minimize magnetically induced currents in the chassis. Heavy, solid construction is a must, and mounting the 26 tube sockets on a suspended subchassis while not absolutely necessary does help. Mine are mounted directly on the chassis which is mass loaded with a lot of material. (resilient floor tile works well to do this) All of that said, I was most sceptical about this design when I first started working on it, over the course of years it has supplanted every other line stage I have designed. Still evolving it continues to get better. I would be happy to advise simplification where possible. The earlier version uses a simpler B+ supply using a single 6EM7 - rectification can be tube or SS. I can furnish a schematic on fairly short order i f you want one. Battery bias will work fine. Output transformer quality is paramount to the end result, spend the most money here, everything else can be upgraded down the road. (15K primary Z is the minimum I would recommend) The line stage is used with a 300B SE amplifier with about 24dB of gain into a speaker system that with room reinforcement is exceeding 100dBspl/w/m efficiency and is extremely quiet. (Line stage gain is about 4dB - all I need, but with an output Z of only 300 ohms allowing me to use unshielded silver wire in my interconnect cables.)
www.kta-hifi.net |
#10 | |
Hi, Thank you for clarifying my confusion. With regards to the cathode bypass caps, what value would be optimum? I'm thinking of feeding the filaments of each tube constant current. (LM317? Or a higher powered version) For my transformer, I'm actually thinking of using some high H chokes (with rather high DCR) in multiple LC configurations to drop the voltage, as compensation for not using a regulator circuit. As much as I like seeing tubes in action, I'm trying to not use additional tubes due to the year-long hot weather here in Singapore. Is this advisable? As for chassis design, I'm thinking of internally sub-dividing a main chassis into 2 separate suspended subframe, shielding these 2 sections (power and signal) by means of copper or aluminium plates. The main chassis will house the subframes to give an overall view of a single chassis. The remote control circuit would probably be mounted directly on the main chassis. Thank you! |
| Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps | MartyM | Tubes / Valves | 3 | 16th October 2008 04:52 AM |
| Guitar Preamp = MIC Preamp = other preamp ,,are they all same? | Paswa | Solid State | 1 | 12th March 2008 05:16 PM |
| twisted pear Preamp/other suggestions for Preamp kit | LukeDuke | Chip Amps | 1 | 1st February 2008 09:57 PM |
| Electret mic preamp - will phono preamp work? | darthmullet | Analogue Source | 6 | 12th October 2007 07:32 AM |
| wiring preamp outs on a preamp | bonsai171 | Solid State | 4 | 22nd March 2004 10:13 PM |
| Page generated in 0.16114 seconds (85.73% PHP - 14.27% MySQL) with 11 queries |
