| diyAudio Sponsor | ||
Morning All,
I have finished the wiring for the 'scratch' phono preamp designed by Triode Dick. I think I've got everything squared away and am unclear on only one last thing. I'm trying to understand the heater wiring for the ECC83 & 5751 valves. The LT supply is outputing a regulated 12.0 VDC. I am currently applying the 12 VDC across pins 4 and 5 of each valve by running hookup wires from the positive terminal of the 10 uF caps to pin 4 of each valve and from the ground leg of the 10uF caps to pin 5 of each valve. As I understand it this is connecting the heaters of each valve in series....am I correct? The only other thing i can think of is: o--------4----------4--------------4 12 VDC 0--------5----------5--------------5 Any clarification would be much appreciated.
#2 |
What you've described is running them in parallel, not series. And parallel is what you want.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#3 | |
Thanks SY. By 'what you've described' are you referring to the wiring I already have in place (each valve with its own connection to the 12 V) or what I have drawn above (+ cap -> 4 -> 4 -> 4; - cap -> 5 -> 5 -> 5)? |
#4 |
Each valve is in parallel with the next valve.
The two heaters in each valve are wired in series. |
#5 |
Oh, I see, you mean daisy-chaining instead of individual? Electrically, they're about the same. I tend to daisy chain as much as is practical so that there are fewer AC-carrying wires strewn around the chassis. But it depends on layout- in my EL84 amp, I have a separate twisted pair going to each channel, but the tubes within the channel are daisy-chained.
#6 |
That's what I meant Sy...wasn't sure if there was going to be a problem by not 'daisy chaining' the valves together.
Here's another question: I'm using a Hammond 250-0-250 CT transformer for the HT...I'm seeing B+ of 356 VDC as opposed to the 275 as described in the schematic. 250 VRMS x 1.414 = 353.5 VDC This 353.5 VDC will be less after the rectifier drop...no? So the B+ at the first cap after the rectifier should see something less than 353.5, not more...no? Shouldn't the EZ80 be dropping a fair amount of voltage across itself? I don't have the numbers in front of me but the plate voltages were all within spec. It's the cathode to plate voltage that one has to watch for...right? TIA |
#7 |
If that's the loaded voltage, you'll want to bring it down. A bit of resistance added in series with each choke will be beneficial to ripple and noise while getting the output voltage down to spec.
Check the AC voltage at the heaters to make sure it isn't too high.
#8 |
Thanks again Sy.
Bare with me while I try to figure this out...my background is in mechanical engineering and I'm still struggling to fully understand this stuff from the few classes I took. I need to reduce the total B+ voltage by 81 volts. Can it really be as simple as dropping 27 volts across each of the three resistors that will go in front of each choke? I think the B+ current is ~ 25 mA so that would require a 1K 1W resistor in front of each choke....please tell me it's that simple. Oh, I don't need to worry about the heater voltage as it is being supplied by a separate circuit. |
#9 | |
Heghlu'meH QaQ jajvam! |
#10 | |
| Heater wiring help! | losacco | Tubes / Valves | 1 | 23rd May 2009 08:33 PM |
| A heater wiring DOH! moment?? | maynardg | Tubes / Valves | 4 | 4th March 2007 10:31 AM |
| !2ax7 heater wiring? Series / parallel? | glaznost45 | Tubes / Valves | 1 | 27th February 2006 11:51 AM |
| heater wiring | tenderland | Tubes / Valves | 6 | 2nd March 2005 08:14 PM |
| Page generated in 0.12961 seconds (78.56% PHP - 21.44% MySQL) with 10 queries |
