| diyAudio Sponsor | ||
Accidentally dropped a JJ 12AU7 tonight. It fell about three feet onto a concrete floor. The glass didn't break, but it did bend more than a few pins.
What's the likely damage? Microphonic? Shorted grids? Should I just give up and pitch it, or plug it in and see if it still works? |
#2 |
I would straighten the pins and plug it in. Live dangerously I say. If the glass didn't break, it's probably ok. Of course, you could check for internal shorts with an ohmmeter first if you'd like to be safe.
Victor
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University |
#3 |
I've dropped a lot of small tubes, and none have ever been damaged. In fact, I once dropped a beer bottle into a quad of RCA 6SN7s from 2 feet, and I still use them today. I have no idea how they survived that -- I guess they rolled their way to safety. They are more rugged than they look! Give it a whirl.
#4 |
Tube didn't break, getter didn't turn white, gopher it.
Go look at the impact (G rating) of tubes sometime. It's up in the hundreds of Gs. One metre, it's nothing; couple dozen G. If the glass didn't get damaged, the vacuum isn't compromized, straighten the pins (carefully!), and go. Aloha, Poinz |
#5 |
Dropping your amp with the tubes IN it on the other hand is a different story
I've got an old 42 that has been dropped a few times and still works. The small tubes seem to hold up very well! I have tile over concrete floors in my room, and I have dropped a few 7 and 9 pin tubes HARD. Am amazed at their agility!
always preach the gospel- and when necessary use words. |
#6 |
broken filament is another possibility.
Murray |
#7 |
I noticed (from destructive experience) that the glass on some (9-pin) tubes is thinner than on others.
| Dropped a SIF Ba | exurbia | Tubes / Valves | 21 | 15th April 2008 08:27 PM |
| Dropped another Bose-Bomb! | ratman542 | Multi-Way | 110 | 1st June 2007 12:38 PM |
| My EAR834 dropped dead! Help! | contaxchen | Tubes / Valves | 8 | 4th January 2004 07:50 PM |
| Page generated in 0.10212 seconds (73.58% PHP - 26.42% MySQL) with 10 queries |
