| diyAudio Sponsor | ||
Hi all,
I have designed my amp so that the input jack is at the back of the chassis but I need to run the input to the front of the amp (internally). Should I use shielded cable or does it not matter? As an aside, for anyone who has been following my very slow progress, my chassis arrived from the metal shop a couple of days ago. I must admit the fabricators (although terminally slow) have done a very good job and copied my plans exactly. It is extremely robust. I now know that 3mm aluminum is actually quite solid, it is perhaps a little over engineered! I will post a couple of photo's in the next day or two. Cheers, Rob |
#2 |
Hi Rob,
I would tend to use good quality shielded cable just because it is correct and proper design. Sometimes I make my own with a length of teflon/silver wire inside a piece of braid. You could also try twisting two pieces of hook-up wire together, using one as a ground, and run it along close to the chassis keeping it away from AC power/filament lines. In either case, if you must cross an AC line, keep the wire intersection at 90º to minimize hum pick up. Both of these procedures will add a tiny bit of capacitance to the input, but should not cause noticable rolloff if kept as short as possible. Looking forward to any pictures. Victor
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University |
#3 |
Tanks Victor,
Shielded it is. Cheers, Rob |
| shielded power cable | rkreim | Vendor's Bazaar | 6 | 23rd March 2007 02:33 AM |
| shielded cable vs ribbon cable | Leolabs | Parts | 2 | 23rd July 2006 05:21 PM |
| RG59 Coaxial shielded cable for input wiring? | John Biles | Solid State | 77 | 8th December 2005 09:29 PM |
| Shielded cable for input signal | falcott | Parts | 2 | 5th September 2004 02:45 AM |
| Should Intercnnects & Speaker Cable be Shielded? | ralph-bway | Everything Else | 4 | 5th January 2004 02:28 PM |
| Page generated in 0.08977 seconds (62.52% PHP - 37.48% MySQL) with 10 queries |
