| diyAudio Sponsor | ||
G'Day guys,
I picked up two motor run capacitors I thought might be useful for some future project for almost nothing while browsing around some electrical parts shops when away with work. ASC X386D Dual motor run 20uF/4uF. My dumb question is, I have been searching for some data on this cap and have found the appropriate web site, http://ascapacitor.com/Products/x386d.htm but cannot find what sections of the dual capacitor the three pins connect to. Is there a standard pinout for these things, or does someone know offhand what they are for this brand? Thanks, Chris. Oh, have just been told there is no such thing as a dumb question, just dumb people! |
#2 |
I don't no much about motor capacitors but i would think one pin is neutral, one is motor run and the other is motor start.
#3 |
From what I can gather, these things are for devices such as air conditioners that require a large motor run cap for the compressor and a smaller one for the fan. I figured that one of the pins would be common ant the other two for the different caps, but the question is which is which? Unfortunately I do not have a capacitance meter. Maybe I could apply a low voltage from a bench power supply across each of the pin combos and then time the the discharge rates when I place a multimeter across the various pins, the longer discharge being the higher cap value.
I was hoping that someone might know what the standard pin configuration was on these things ![]() Cheers, Chris |
#4 |
All the ones that I have are marked, but I would just use an ohmmeter, fine the two leads with the most resistance between them and that should be the two hot terminals i would think
Heghlu'meH QaQ jajvam! |
#5 |
I have used this air conditioner motor run caps from ASC. The middle pin is the common ground for the 30 and 4uf sections.
Great caps for PSU. HTH. |
#6 |
I emailed ASC and received a reply. As it turns out, the top of the can is marked, but it is so faint on mine as to be almost invisible. With the label facing you, the top centre connector is common, marked 'C', the left is 'FAN' 4uF, right is 'HERM' 20uF.
Thanks for the help and suggestions, Chris |
| motor run capacitor | milen007 | Parts | 12 | 28th June 2008 05:49 PM |
| Dumb question, but... | johnm | Tubes / Valves | 3 | 13th June 2008 10:14 PM |
| Motor Run Capacitor | Zap | Tubes / Valves | 2 | 14th May 2008 09:59 PM |
| Aleph capacitor choice- elco vs motor start | Tweeker | Pass Labs | 3 | 16th December 2005 02:46 PM |
| Electric motor capacitor for crossover ? | djdan | Multi-Way | 15 | 12th October 2004 04:10 PM |
| Page generated in 0.09130 seconds (76.49% PHP - 23.51% MySQL) with 10 queries |
