diyAudio Sponsor
Old 12th August 2007, 04:44 PM   #1
pftrvlr is offline pftrvlr  United States
Default How to match tubes?
I want to find a matched pair of 6c19 from a bunch of 20. But I don't have a tube tester. All I have are DMM and o'scope. What is the best way of mathing them?
Old 12th August 2007, 06:53 PM   #2
You can make a temporary tube tester out of the parts you would use for an amp and your dmm.
Old 12th August 2007, 08:59 PM   #3
Dave Cigna's Avatar
If you have a working circuit in which you intend to use them, then plug in each tube and measure the cathode, plate, and grid voltages with no signal. (The grid voltage can give an indication of grid current.)
If you have a signal generator (could use a test CD or even the sound card in your computer) then you can further rank the tubes by mu. Apply a signal to the grid and use your oscilloscope to measure the signal level at the plate.
January 20, 2009: Bush's last day
Why match tubes? oldmanStrat Tubes / Valves 8 29th May 2009 02:57 AM
WTT: Various tubes for 6CA4/EZ81 rectifier tubes GordonW Swap Meet 4 27th August 2008 12:37 AM
To Match Impedance on DI Box, or Not to match? MisterAlex Instruments and Amps 1 21st November 2004 10:09 AM
Crucial to match tubes when running PSE? G Tubes / Valves 25 25th September 2003 08:15 PM
Page generated in 0.06719 seconds (67.62% PHP - 32.38% MySQL) with 10 queries
