| diyAudio Sponsor | ||
What is the average gain of a phono amp?
What is the average gain of a preamp? What is the average gain of a linestage? What is the average gain of a power amp? I am guessing linestage and poweramps have 0db? Thanks |
#2 |
How long is a piece of string?
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#3 | |
Ears aren't microphones. |
#4 |
#5 |
I am guessing this means the gain of a power amp is dependent on its power handling. This makes sense to me now, i don't think i thought about it hard enough.
But that can't be true for a preamp. Can it? Their has to be some guideline to follow or else the first notch on the attenuator could be full power. |
#6 | |
Heghlu'meH QaQ jajvam! |
#7 |
A power amp's gain depends on rated output. Typically designers aim for 1.5-2 volts for full power output. A 1 watt amp's gain will be much lower than a 200 watter's. For pre-amps, consider the output level of common sources, or those you'll use, and the rated voltage for full output of your amp. You'll want some extra gain to make up for low level recordings but I can't think of any situations personally requiring more than 6-10 dB.
| Gain Blockwith Variable Loop Gain | Bonsai | Solid State | 17 | 11th July 2008 02:40 PM |
| How much gain should I have? | komen | Chip Amps | 2 | 26th March 2006 01:32 PM |
| Heretical Unity Gain line stage PLUS a little gain ? | yagas | Tubes / Valves | 7 | 24th January 2006 01:30 PM |
| Unity Gain Operation (or low gain) | Tomo | Chip Amps | 12 | 22nd January 2004 01:47 AM |
| Q on amp gain | Andrey | Solid State | 1 | 18th June 2002 09:48 PM |
| Page generated in 0.09190 seconds (77.54% PHP - 22.46% MySQL) with 10 queries |
