Old 8th August 2007, 08:02 PM   #1
poynton is offline poynton  United Kingdom
Magneto the Gravity Man
poynton's Avatar
Location: A life on the ocean waves when I'm not at home in N. Wales (but I'm not Welsh so no sheep jokes!)
Default Hybrid Tube / Mosfet Amplifier
Hi.
I found this amplifier some time ago and thought it was time to give it a try.
The original was wired point-to-point.
The transformer, 35-0-35v, was shared between both channels.
I propose to make a dual mono amp.
R1/10=47k C1=100uF/100v
R2=220k C2=100nF/250v
R4=33k C3=100uF/63v
R5=820k C4=4700uF/100v
R6/11=1K
R7=4k7, 1W
R8/9=150r
R12/13=100r
V1=ECL86
Q1/Q2= 2SK135/2SJ50
One thing I think should be done is to separate the supply to the driver from the output stage.
Also required is a slow start/anti-thump.
Any other improvements?
Andy
Old 10th August 2007, 06:27 AM   #2
poynton's Avatar
Hi.
No-one got any comments / suggestions for improvements?
Andy
Old 10th August 2007, 06:38 AM   #3
I think it looks great, and it also seems like a great idea. I have been thinking about a similar project for a while now. But when it comes to exact suggestions about your design I am afraid my current knowledge is not really enough. I need to learn more about mosfets and tubes.
Old 10th August 2007, 08:59 AM   #4
ilimzn is offline ilimzn  Croatia
Originally posted by poynton
Hi.
Andy
Honestly? I would forget about connecting the tube and MOSFET stage the way it is in that schematic, and especially powering it from the same power supply. Why? Have a go at estimating the output swing of this amp... and what limits it.
Old 10th August 2007, 09:14 AM   #5
poynton's Avatar
Why?
I have read that this should be done which is why I put it in the original post.
Unfortunately, my knowledge of tubes is limited which is why I posted . Please explain.
Andy
Old 10th August 2007, 12:12 PM   #6
SY's Avatar
Try running the loadlines for that voltage and load resistance on the tube's curves. That should illuminate things.
I'm not an expert on MOSFETs, but it doesn't look to me like the biasing will work, either. You may also wish to consider what the source impedance of the tube driver is, compare with the MOSFET input capacitance, and see what your bandwidth ends up being.
If there's a sucker born every minute, where do the rest of them come from?
Old 10th August 2007, 12:18 PM   #7
the_manta's Avatar
Exactly SY !
Forget about using an ECL86 at that low Voltage....
You should rather build a nice little amp with the ECL86.
Furthermore these Mosfets are rare. Buzt can be replaced by BUZ900 ... and so forth
Regards, Simon
Терпенье и труд все перетрут
Old 10th August 2007, 05:24 PM   #8
poynton's Avatar
As I said, I have a limited knowledge of tubes
This output configuration is used in several schematics I've seen. Of course, that does not make it correct but it must work.
Regards, Simon
I have enough for several amps !!
Andy
Old 10th August 2007, 05:32 PM   #9
the_manta's Avatar
Lucky guy....
Did you see this thread ? Your Mosfets will work well with it ! Only thing you need is a seperate PSU for the t00bz.
Regards, Simon
reliable tube/mosfet hybrid amp JAZZ2250 Solid State 71 20th August 2012 05:18 PM
MOSKIDO - Hybrid Tube/MOSFET Amplifier Kashmire Pass Labs 7 22nd September 2011 08:30 PM
24V Tube IRF610 MOSFET Hybrid HPA lineup Solid State 10 23rd October 2008 02:36 AM
Essential Audio hybrid tube/mosfet amp kit FS ppickard Swap Meet 1 6th April 2001 02:23 PM
Copyright ©1999-2013 diyAudio
