| diyAudio Sponsor | ||
I know rectifiers get covered a lot, so sorry for for adding noise....
What's the biggest commonly available 6V heater full wave rectifier tube? I don't like the heat given off by dropping a 6.3V winding down to 5V, nor using 2 damper diodes with their big heater draw.
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#2 |
6BY5 - comes in G and GA flavors. 6AX5 might also do if 6X4 or 6X5 isn't enough - kinda like an octal EZ81...
#3 |
hey-Hey!!!,
The highest current, octal dual diode I've found is the 6AX6. At 2.5A of 6.3, you could light a pair of 6AX4's and save 0.1A. That is IFF you could find a 6AX6. I've been using 83-cent 6DE4's I got from AES when they went on sale a bit ago. cheers, Douglas
the Tnuctipun will return |
#4 | |
#5 |
No problem.
#6 | |
The 6AX5 drops a lot more volts than a 6CA4/EZ81. Heating time is comparable, as is output current. The 6CA4 can take a lot more capacitance in the first filter element than the 6AX5 too IIRC. cheers, Douglas
| how to wire 6.3VDC heater on a heater with center tap (12.6V series, 6.3V parallel)? | jarthel | Tubes / Valves | 9 | 14th April 2012 05:36 PM |
| another biggest, most, | tomtt | Multi-Way | 3 | 21st October 2008 04:08 AM |
| Biggest Spl Per £ | bob123 | Subwoofers | 10 | 25th April 2006 09:50 PM |
| Any benefit to DC heater on parallel supply rectifier (GZ34)? | leadbelly | Tubes / Valves | 2 | 13th February 2006 11:00 AM |
| Anybody heard about Tarzian Silicon Rectifier for Tube Rectifier Replacement? | zxx123 | Tubes / Valves | 4 | 21st February 2005 04:02 AM |
| Page generated in 0.09177 seconds (72.16% PHP - 27.84% MySQL) with 10 queries |
