PP EL34 circuit wanted
Old 8th August 2007, 02:01 PM   #1
Norris Wilson is offline Norris Wilson  United States
Default PP EL34 circuit wanted
Hi everyone,
I have a freind who is in search of a quality PP EL34 amplifier to build.
He has recently owned an Eastern Electric M520 with NOS tubes and he really liked it. But having audio neurosis like I do, he is in search of something better, possibly a direct or transformer coupled design.
Any and all design ideas are welcome, for the goal is a quality amplifier that plays the music without layers of veiled component characteristics.
Norris Wilson
Old 8th August 2007, 03:25 PM   #2
ashok is offline ashok
ashok's Avatar
Do an EL34 search.
You will find a few LONG threads ! The topic was almost beaten to death . You will spend a lot of time sifting through those threads !
AM
Old 8th August 2007, 09:26 PM   #3
Bandersnatch is offline Bandersnatch  United States
hey-Hey!!!,
There is a lot to an amp, circuit, parts, layout. What sort of thing does your friend want? I'd suggest a low voltage, conservative Class A design with a beefy power supply. For the circuit, I'd suggest a two stage with plate-to-grid FB on the EL34's. It would deliver ~20W...
cheers,
Douglas
the Tnuctipun will return
Old 9th August 2007, 11:29 AM   #4
OzMikeH is offline OzMikeH  Australia
This might be suitable. I just started reading it yesterday to learn how tubes work. There are 2 articles, Single ended and push-pull El34 amp projects written for Lunhahl. If you start with this you'll understand enough to tweak it afterward.
http://www.diyaudio.com/forums/showt...498#post470498
Mr Liang does an EL34 pp amp which would get you the tubes, chassis and transformers, you can rebuild it from there.
PP EL34 circuit wantedHide this!Advertise here!
Wanted. Simple EL34 Push Pull Design jack firebrace Tubes / Valves 51 29th July 2013 12:47 AM
EL34 SE triode mode A class sch wanted trancy Tubes / Valves 14 10th January 2008 10:16 AM
EL34 in place of a 6AS7G (used in the supply circuit as a pass tube). how? jarthel Tubes / Valves 27 9th June 2006 12:04 AM
EL34 Feedback circuit dr._sleep Tubes / Valves 3 17th October 2005 05:01 PM
12AX7, EL34 or 6L6 design wanted Fiat1 Tubes / Valves 22 13th September 2005 06:35 PM
Copyright ©1999-2017 diyAudio
